2 Pages 12>
Airbox camera? Options
Senna94
#1 Posted : 13 September 2011 12:22:17
Hi guys,
Has anyone seen the missing airbox cam housing from the model?
Its not even on the Amalgam model, Does anyone know why this is missing?
Admin/Tomick?
Thanks!
Building the McLaren MP4-23
Warthog
#2 Posted : 13 September 2011 18:25:32
Couple more from when i was there...
schueyking
#3 Posted : 13 September 2011 21:01:00
BigGrin Cracking photos! Just awesome!!!!BigGrin
Senna94
#4 Posted : 17 September 2011 15:16:22
Tomick/admin,
Is the air box cam not included with the model?
schueyking
#5 Posted : 17 September 2011 15:38:52
BigGrin You could always make one yourself easily.BigGrin
Senna94
#6 Posted : 17 September 2011 16:05:56
Care to share how you'd make one mate? BigGrin
#7 Posted : 17 September 2011 17:28:37
Senna94 wrote:
Tomick/admin,
If its not shown in photos of the model then its highly unlikely
Warthog
#8 Posted : 17 September 2011 18:24:56
Making one with 1mm plastic sheet.. needs slight filling etc.
#9 Posted : 17 September 2011 18:42:06
The item being made in your photo is not the item Senna94 is referring to, as the top camera is supplied in issue 14.
Look at the black circled item in photo 1 and seen again in P2, which looks like an airbox side camera (or at least that is where they used to be located), in addition to the top camera, I'm not quite sure what the side airbox item is if its not a camera?
Warthog
#10 Posted : 17 September 2011 18:46:14
The photo I've shown is the top Camera pod being resparayed with the correct MP4 Red and the white one being made with 1mm plasticard is to go on the side as in the Photo's Tomick. Just putting the other one with it to show as reference.. Think i know what i'm doing lol Flapper
#11 Posted : 17 September 2011 18:48:45
I did NOT suggest that you do not know what you are doing and there's no need for flippancy!
Warthog
#12 Posted : 17 September 2011 18:59:07
Whoa whoa whoa slow down Mr T... Notice the Poking tounge???
#13 Posted : 17 September 2011 19:04:54
I took it that the unpainted item was in someway part of the painted item that you might have made your own, and the tongue I took to be just that, but I can now see it was meant in jest.
That aside, its great to see the changes youre making to make your model as authentic as possible, and likley the end result better than the Amalgam 2.8k version.
Keep at it as your build is a credit to you Cool
Warthog
#14 Posted : 17 September 2011 19:08:58
Hey no hurt done Sir and thank you for your kind comments of encouragement.. you should take some credit for the Official builds your doing here too.. whish I had your job making part builds all day..
#15 Posted : 17 September 2011 19:14:10
That only scratches the surface LOL
Warthog
#16 Posted : 17 September 2011 19:30:20
Another one.. does not take long to do really.. Basic skils too
S2ksean
#17 Posted : 17 September 2011 19:33:32
U should put these pics up on ur build warty
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
Warthog
#18 Posted : 17 September 2011 19:36:42
I will do Sean.. just knocked them up in the past hour so will add them soon..
S2ksean
#19 Posted : 17 September 2011 19:39:36
Nice is that just balsa it's made from?
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
Warthog
#20 Posted : 17 September 2011 19:47:32
It's made from 1mm plastic sheet. 5 pieces layered on top of each other and then filled down to form the same shape.. I'll do another and do a step by step so to show how its done... you could do it from balsa but i think it will be too fidly
2 Pages 12>
This page was generated in 0.341 seconds.
