GT40 fuel pumps Options
Eagle
#1 Posted : 20 November 2020 14:11:42
Red Medal: Red Medal
I'd like to improve the appearance and look of the fuel pumps in Issue 7; they don't look period correct, finding photos of these old race cars is difficult: any ideas welcomed
Getty Gulf engine detail
GlynD
#2 Posted : 23 November 2020 12:33:51
Rank: Semipro Level 2
Hi Eagle, I found a good source of images on You Tube I hope these are helpful to you.
GlynD attached the following image(s):
Eagle
#3 Posted : 23 November 2020 13:10:54
Thank you for the photos, they are much better than what I have found; there are differences in the plumbing between the two however, perhaps these are photos from a semi accurate restoration....
Anyone have any ideas for someone to do a 3D print on this?
GlynD
#4 Posted : 23 November 2020 14:47:03
Hi I believe these are from chassis no,s 1075 and 1076 when they where displayed at the Amelia lake concours about 3 years ago
Eagle
#5 Posted : 26 November 2020 15:47:17
Thanks GlynD for the photo; decided to modify the kit fuel pumps as I don't have any 3D graphics experience and I'm too old to learn it. I cut off the pump bottoms and reversed them, shortened them and then added material to the bottom under the flange. , scratch built some switch parts and scrounged up some lines from a parts box, washers, etc. Still need to work on the top flange and add more fuel line fittings either from resin or metal. I also reworked the left floor panel and scratch built the compartment cover to look like the period correct photo
GlynD
#6 Posted : 26 November 2020 23:29:08
That’s looking a lot better I’ll be doing something similar as well , I’m wondering how much other wiring / fuel line detail will be included 🤔
bfam4t6
#7 Posted : 27 November 2020 03:31:26
Publisher Medal: Featured Build of the MonthBuild-Diary Medal: Build-Diary Medal of Honour
Nice work Eagle, and thanks for the great references Glyn! I definitely plan to modify this kit quite a bit, and this will be very helpful
-Dustin
“Details make perfection, and perfection is not a detail.”
-Leonardo Da Vinci
Currently Building:
Porsche 2.7 RS
Currently Collecting
Jaguar E-Type, Ferrari F40, Ferrari 250 GTO, Lamborghini Miura, Ford GT40, Ecto-1, Japanese Zero, Porsche 917, Lancia Stratos
Brian Whitworth
#8 Posted : 31 December 2020 23:55:35
I agree with the need to upgrade from the facet Red-top fuel pumps to the ones fitted to all the original cars as they came out of the factory (the majority were from Slough) which were Steward Warner 240s and a Fispa fuel filter/ regulator that was fitted between the pumps and the carburettor’s. The attached picture is my effort at reproducing the said parts.
Brian Whitworth attached the following image(s):
bfam4t6
#9 Posted : 01 January 2021 00:24:23
Nice work Brian! Looks much better than the stock kit. Did you build from scratch?
-Dustin
-Leonardo Da Vinci
Currently Building:
Porsche 2.7 RS
Brian Whitworth
#10 Posted : 01 January 2021 02:41:32
I cut the top and bottom off both pumps supplied and turned the new parts on the lathe using alloy, the Fispa fuel filter/regulator was made from scratch. I just hope this model dose not take me as long to finish as the one in the garage as I started that one in 1986 hopefully it should be on the road early this year.
Eagle
#11 Posted : 01 January 2021 13:54:30
Great work Brian; much better than what I was able to cobble up; must be nice having a lathe to machine things up.
GlynD
#12 Posted : 01 January 2021 20:14:39
Very impressive Brian especially the pipe work I constantly feel the need to up my game which is no bad thing 👌🏻
#13 Posted : 01 January 2021 20:21:16
Some really nice upgrades going on here.
Keep it coming.BigGrin
Brian Whitworth
#14 Posted : 01 January 2021 23:08:27
Yes the pipe work was the easiest part, a length of piano wire, a few 12 BA nuts and the outer casing of some electrical wire for the piping the main problem is I have rather large hands and I am forever dropping small items such as nuts and screws Did you notice the chassis plate above the header tank?
And in reply to Eagle if it was not for the lathe , driller, miller and welding gear I would not have been able to build the full size model.
GlynD
#15 Posted : 02 January 2021 14:21:42
Thanks for the tips Brian I had been wondering about the pipe unions but your idea is brilliant and yes I noticed the chassis plate 👌🏻
This page was generated in 0.063 seconds.
