13 Pages «<34567>»
Gandale’s Enhanced Trumpeter Bismarck Options
DaDokta
#81 Posted : 24 November 2020 12:05:50
Incredible work so far!
May i ask - which glue do you use to attach the PE?
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#82 Posted : 24 November 2020 17:44:33
Thanks Walter, appreciated.
Just now I'm using Zap medium CA and find a tiny amount is all that is needed for a good bond. Apply too much and the bond becomes brittle. My preference would be to use GatorGrip Thin Blend, but am finding it impossible to get over here..... Just have to keep trying I suppose....Cool Cool
#83 Posted : 25 November 2020 00:02:48
Decided to have a go at something a little more complex. Went ahead and assembled one of the paravanes. Once again we find the instructions don't go into any detail on order of assembly so a lot of test fitting was done to work out the best way to assemble. In case anyone decides to have a go with this build I've posted up pics showing the build sequence that worked for me. That's one done ready for priming, only another seven to go....will post up again when done....Cool Cool.. Customary penny placed in shot to give a sense of scale.....
#84 Posted : 25 November 2020 00:55:03
Very nice Alan, and by the standard of your work your near vision glasses must be working.
well done
Trev
admin
#85 Posted : 25 November 2020 05:59:38
I don’t think I’ve heard you cuss during any of our phone calls, but I’d bet the air was blue, while you were assembling that paravane!
Looking fantastic!
Sticky Wickett
#86 Posted : 26 November 2020 22:55:46
Excellent detailed miniature work there Alan. Very nice!Love
Phil W.
DaDokta
#87 Posted : 27 November 2020 07:22:20
Awesome stuff!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#88 Posted : 27 November 2020 17:27:58
Wow, that is just incredible work Alan and so small.Drool Drool
You are going from master of wooden ships to master of etched brass assembly. Cool ThumpUp
CaptnBirdseye
#89 Posted : 27 November 2020 18:57:10
Rank: Superelite
Laugh JEEZ, Al that’s some small scale etched parts! Well done. Pleasure to follow
Regards Gray
#90 Posted : 27 November 2020 21:01:21
Thanks guys, happy to say the eight paravanes have now been done.... These certainly were tricky and slow to assemble....Cool Cool .. Going to do something easier now....Laugh Laugh
#91 Posted : 27 November 2020 23:46:42
Those are such small parts but what some incredible detail.
That was an interesting comment you made about using just a tiny amount if superglue as too much the joint us brittle.
Bit like a light going on because i think that is were i go wrong with superglue in using slightly too much thinking tgat will bind anything but in fact finding the joint is not very good.
Next time i superglue i will try your suggestion.
Tony
#92 Posted : 29 November 2020 17:11:54
That is excellent work Alan! Each of those paravanes is a work of art itself!Cool Cool
This hobby has come on so far since I began in my childhood (must be over 50 years now Crying ) There was a time when those parts would have been a single plastic moulding on the sprue (if you were lucky) or an approximate shaped blob moulded to the deck (if you weren't!)
I think I'm like Tony too - tend to use more super than I need to do the job!Blushing
Always learning!
#93 Posted : 29 November 2020 18:17:33
Yet another brilliant update Alan.
Those tiny items deserve to be in a case of their own.
Just amazing.Love
#94 Posted : 29 November 2020 22:00:24
Excellent work Alan. Your flying through this build with excellent results. I'm still doing painting at moment but time isn't what I have. I can't wait to see more updates 😊
Chris
DaDokta
#95 Posted : 30 November 2020 08:28:22
Those paravanes are a piece of art!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#96 Posted : 30 November 2020 10:32:59
Excellent work Alan Drool Drool
Regards PhilCool
Sticky Wickett
#97 Posted : 30 November 2020 10:45:44
Those paravanes should be in their own display case!Love
Phil W.
#98 Posted : 01 December 2020 00:52:03
Thanks to everyone for looking in and for those that left the very supportive comments, the support is very much appreciated.....Cool Cool
Well, I did say I was going to do something a little less taxing. Can't get any easier than assembling fire hoses. These consisted of 4 parts, simply glued one on top of the other. When dry, bent the small tabs round and secured with a touch of CA. The Pontos instructions here are a little confusing. Instructions say to use 3 parts for each fire hose, yet the pics show the use of 4 parts, so went with 4 to give the fire hoses a little depth. It also looks as if there are spare parts on the fret as I can't see anywhere else where they will be used. No doubt it will become clearer as the build progresses.
Next, decided to start adding the basic etch to the second level of the aft superstructure. The first task was to remove most of the moulded detail and finish off smooth with 1200 grit wet and dry. Drilled out the portholes and some of the hatch openings, then drilled 0.3mm holes for the ladder rungs and glued them into position. Did this now as it would be harder to do with the rest of the etch added. Will post up again once the etch for this part has been fitted so until then, happy modelling all.....Cool Cool
#99 Posted : 01 December 2020 02:02:00
Beautiful precision work Alan.
Those hand holds/rungs are very neatly placed.
Hope it all continues well.
Tony
#100 Posted : 01 December 2020 09:13:55
Very impressive work again Alan.Drool Drool Those ladder rungs look superb.Cool
Guest (27)
13 Pages «<34567>»
This page was generated in 0.228 seconds.
