X-Wing Power Problem Options
shinden252
#1 Posted : 28 November 2020 06:55:10
Rank: Beginner Level 1
I just completed issue 72 of my X-Wing build. When I tried to power on the vehicle, nothing happened. I tried the troubleshooting in the magazine with no success. One point of note is that the labeling on the circuit board for the laser cannon and engine connections is different than shown in the magazine. The other sockets are the same in the diagram and board. The circuit board components also look different on the one I received compared to the picture in the magazine. What else could be wrong? Could the forward sockets be mis-labeled as well. Anyone had this issue?
Wabie
#2 Posted : 28 November 2020 08:52:36
Groups: Registered, Forum Support Team Germany, Official Builds, Tech Support, Moderator, registriert, Administrators
Hello,
that the circuit board looks different is not a problem
unfortunately you have to wait a little longer with the test.
the test can only be carried out with issue 74.
this contains the socket of the external power supply with plug 20.
the test can only be carried out when this is plugged in.
The description in issue 72 is very misleading.
Greetings Stefan
Alle Berichte sowie alle Fotos unterliegen dem Urheberrecht. Verwendung außerhalb dieses Forums bedürfen schriftlicher Genehmigung/Zustimmung meinerseits. © Stefan
Forum Support Team
https://m.youtube.com/watch?v=qIC4f1LE86w
MfG Stefan
shinden252
#3 Posted : 28 November 2020 17:20:44
OH MAN!!! Thank you for the reply!! I was wondering what socket 20 was for for, especially since it was labeled DC power. They ought to note that or send an amendment in the box. I spent a bunch of time troubleshooting the issue.
This page was generated in 0.124 seconds.
