52 Pages «<1314151617>»
1/48 scale U-Boat U230 [Part 3] Options
budgie
#281 Posted : 05 December 2020 20:26:31
Drool Drool Very nice Sticky
If you have any space left will you be stowing essential victuals
Maybe too hot back aft for stowing food thoLOL
Looking forward to your next update
Glad you are under the new competitors build as makes it easier too find part 1 and 2 of your build diary as your link did not work for me
Cool Will pour myself a glass of wine and go on a journey thru your build
Garth
#282 Posted : 09 December 2020 09:37:42
Hi Phil,
Simply at a loss for words.....FANTASTIC!!!
kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
#283 Posted : 12 December 2020 00:47:22
The work on that switchboard just leaves me speechless Phil, just incredible work....Love Love Love .. Can see I've got a lot to learn.....Laugh Laugh Laugh
Sticky Wickett
#284 Posted : 18 December 2020 11:11:57
Good morning from 'The Dockyard'.
Thank you for the kind comments, much appreciated.
So i didn't upload a post last week, even though i had a made a little progress, as i awaited an order of paint and varnish to arrive!Blink
The attached photo shows a heater/motor blower, completed, painted and ready for fitting.
Sticky Wickett
#285 Posted : 18 December 2020 11:15:11
The attached photo shows a length of pipework with a valve/handwheel assembly ready for painting. The pipework was made from 2.0mm diameter solder. I found solder to be the best medium for making pipes as it's easily bent to shape and takes paint well.
Sticky Wickett
#286 Posted : 18 December 2020 11:16:03
Pipework and valve/handwheel assembly painted and ready for fitting.
Sticky Wickett
#287 Posted : 18 December 2020 11:18:03
The attached photo shows both the heater/motor blower and pipework/valve/handwheel assemblies fitted. They are both above the switchboard with the heater/motor blower behind the block tackle on the left hand side.
Sticky Wickett
#288 Posted : 18 December 2020 11:20:00
The next job was to make the overhead supports for the switchboard; 3 in total. Fairly quick to make and the attached photo shows them temporarily stuck with double sided tape to a scrap piece of plastic while i painted them.
Sticky Wickett
#289 Posted : 18 December 2020 11:21:24
Supports fitted on top of the switchboard and anchored to the hull.
Sticky Wickett
#290 Posted : 18 December 2020 11:23:48
The final piece of detail i made was an electrical locker. I used 1.0mm thick plastic sheet glued to another to make the thickness 2.0mm, cut and filed to shape and a piece of 0.5mm brass rod, bent and fitted to form a handle.
Sticky Wickett
#291 Posted : 18 December 2020 11:24:23
Painted, varnished and pin washed.
Sticky Wickett
#292 Posted : 18 December 2020 11:25:27
Electrical locker fitted to the bulkhead, beneath the port main motor switchboard.
Sticky Wickett
#293 Posted : 18 December 2020 11:28:03
That concludes this update.
Thanks for looking in and commenting, much appreciated!BigGrin
Have a good weekend whatever you're doing and happy modelling!BigGrin
Phil W.
#294 Posted : 19 December 2020 10:33:56
Just mind blowing work. This should definitely be put in a museum for all to appreciate.Love Love
#295 Posted : 19 December 2020 13:24:31
Looking as good as ever.
Your attention to all that tiny detail is amazing.
How long do you think now until you get to the end point consider it all complete?
Tony
Kev the Modeller
#296 Posted : 19 December 2020 21:10:53
Utter brilliance as always Phil. Amazing!! Drool ThumpUp
Kev.
Per Ardua Ad Astra
#297 Posted : 19 December 2020 22:24:05
The painting is so true to life with that 'lived in damp and grubby' look and those tiny additions really make this model superb!Cool Cool Cool
Definitely agree with the 'museum' comments!Drool
Very well done.
Sticky Wickett
#298 Posted : 21 December 2020 11:13:17
You're very kind Mark, thank you!BigGrin
Phil W.
Sticky Wickett
#299 Posted : 21 December 2020 11:16:09
Tony
Hi Tony, thank you for your comments, much appreciated. How long until full completion? I estimate Summer 2022.Blink
Phil.
Sticky Wickett
#300 Posted : 21 December 2020 11:17:07
Kev.
Thank you so much Kev!BigGrin
Phil W.
This page was generated in 0.322 seconds.
