10 Pages «<45678>»
Roeland Options
Roeland
#101 Posted : 15 December 2020 15:25:45
The anchors installations are in progress. I added blocks for the palm of the anchors.
Roeland attached the following image(s):
goddo
#102 Posted : 15 December 2020 15:44:57
This looks fantastic.
I am very jealous of your modelling skills Roeland.
Chris
Roeland
#103 Posted : 16 December 2020 15:33:26
Planning to add some anchor buoys.
Roeland
#104 Posted : 17 December 2020 16:24:23
too large - back to the drawing board
Roeland
#105 Posted : 17 December 2020 16:25:10
Does anybody now the size of the buoys?
goddo
#106 Posted : 17 December 2020 16:41:22
Hi Roeland,
It's just awesome looking at you modelling skills.
I have attached a few shots of HMS victory anchor buoys and although I don't have dimensions, I assume that with a bit of scaling and comparing to the size/spacing of the rigging and ratlines, a fair attempt could be made to create one?
goddo attached the following image(s):
Roeland
#107 Posted : 17 December 2020 16:46:14
great - thanks
Roeland
#108 Posted : 18 December 2020 16:31:16
I made it smaller....
goddo
#109 Posted : 18 December 2020 16:46:08
Nicely done Roeland.
Roeland
#110 Posted : 19 December 2020 15:42:45
2 Anchors are now in position.
goddo
#111 Posted : 19 December 2020 18:24:32
Those anchors look good Roeland and the buoys seem well in scale. Brilliant.
Chris
Roeland
#112 Posted : 21 December 2020 14:53:09
All 4 anchors are now in place.
DaDokta
#113 Posted : 22 December 2020 09:47:40
A really superb build! Congrats!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Roeland
#114 Posted : 26 December 2020 09:48:55
Starting to make the forecastle guns.
Roeland
#115 Posted : 28 December 2020 15:56:27
Forecastle guns are now nailed to the deck - a tricky operation with all the rigging in place.
Roeland
#116 Posted : 28 December 2020 16:05:30
Another question - as per attached picture I noticed these proportions to be wrong on my model and several others on the forum. Some however managed to get this right? Did I do anything wrong or was it a matter of correct modification?
z8000783
#117 Posted : 28 December 2020 16:09:01
Groups: Unapproved
Luck rather than judgement I suspect. There are so many sources around for this, you can take your pick.
Roeland
#118 Posted : 30 December 2020 16:52:37
Busy making the ship's boats. I hope to add 2 scratch build 25 ft cutters. I could not find any plans so I based it on the 18 ft cutter; just a bit larger and added an extra support (on the right; one frame finished ; one still to be cut). I'm not sure where to get such a thin plywood so I laminated 2 sheets of 0.8 mm balsa wood; then reinforced with book binders glue before cutting.
#119 Posted : 30 December 2020 17:55:13
Doing a super job. She's looking very nice indeed.
Chris
Roeland
#120 Posted : 08 January 2021 17:57:08
Playing around with the pinnace.
10 Pages «<45678>»
This page was generated in 1.829 seconds.
