Hi coming along very well lots of great detail being added to this,cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Looks better and better with each update Alan. Tony Happy Modelling
Stunning work Alan. You are definitely a plastic modeller. Your PE skills are amazing. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
More excellent work Alan. Question: In post #116 you have the part held in what looks like a vice. a) is that correct? b) does it vacuum clamp to the cutting mat its on? Doh, that`s two questions. I have an edge of table vice, but if I drop anything I have to beat the carpet monsters to it. If this adheres to a cutting mat I can put it further back on the table to confound the little demons. I ask because my left thumb is getting worse for grip and it may be a solution to my problems. Can`t get to see a specialist with the way things are at present, proven by the fact that my wife is still awaiting cataract ops on both eyes that were cancelled three days before the first lockdown early this year. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Thanks again for all the supportive comments guys, appreciated.... Have now decided to jump in at the deep end and start working on the hull of this beast... will post up once I've had a good look and see what needs to be done.... @Derek, I use a multitude of different thing to hold pieces in place but the two vices below are probably the ones I use the most. The first is quite weighty so don't really use the suction pad, I find for most uses the weight of the vice means little movement on the bench. Very versatile, can hold items at various angles which I find very useful... If I do need to clamp it down then I tend to place the vice onto a sheet of toughened glass. The second vice I find works very well for holding some of the smaller parts. Can be clamped to the edge of the desk but I prefer to have it on the centre of my work area... Works for me.... Hope this helps... Regards Alan Gandale attached the following image(s):
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,713 Points: 17,291 Location: ipswich
I'm guessing this is going to be pretty big... Looking very impressive.
More outstanding PE work on that aft superstructure Alan. I am thoroughly enjoying watching your first forays into using this media and you never cease to amaze me with how skilled you seem to be with it already!
Very well done yet again Alan, keep it coming.
Kev.Per Ardua Ad Astra
Thanks guys, long way to go and lots to learn on the journey.... loving the challenge though..... @Roy - she's certainly not small... length 1265mm with a 188mm beam but the detail is tiny..... Regards Alan
Thats a very large size model Alan. Do you put them all on display when you finish the models? Tony Happy Modelling
Stunning work as always.You will need a LOT of paint.I think I used 6 bottles of Vallejo on my 1/200 Arizona hull.
Happy New Year to everyone, hope you all had a wonderful festive period. For me, I decided to take a complete break from modelling for a couple of weeks. Felt like I needed to chill out, enjoy the festivities and recharge. Now we’re into a new year its now time to get back to doing the serious stuff. My thanks to all who have looked in a commented, as always it is very much appreciated. Have started work on the hull and here I got a big surprise, on just how much work is needed to be done to the hull section prior to attaching etch, prop shaft housings, rudders etc. Close inspection of the hull revealed many (long) seam lines that needed to be dealt with plus some pretty deep depressions that needed filling and sanding. Before I got down to the business of filling and sanding I glued the hull cross members in place and the two sections of the bow, then let it all dry. Removed all the seam lines before doing some putty work to sort out the depressions, then removed all the moulded detailing that will be replaced with etch. Also noticed the hole at the front of the bow was situated too low so filled this and sanded ready for re-drilling. Now ready to start adding the detail so until then, happy modelling. Regards Alan Gandale attached the following image(s):
Hi Alan, Sounds like fun and a lot of hard work, but it is looking good and well worth the effort, Best Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Great work Alan. The hull is quite flimsy without them stays an deck in place isn't it. Looking well after the filling and sanding. What jig is it you are using to hold the hull. Would come in handy on some of my big kits. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
More fantastic work Alan. You're really going to town on this one.
Excellent work Alan.  all that filling and sanding goes to show it is not to dissimilar from wood. Keep up the great work. Mark Regards Markwarren (Mark) Admin
Nice work Alan. I guess some of these kits do need the “old days” attention in sanding and filing but i always think that goves you a sense of achievement when its finished and you look at it snd say to yourself “i had to fix that, i had to fix that” and you can feel satisfaction on a job well done. Tony Happy Modelling
Great work there Alan. Well done sir! And after Boris's announcement tonight, we will no doubt be getting more modelling time. Stay safe everyone and get your vaccination asap. Chris
Thanks again guys for looking in and all the supportive comments, appreciated..... Got some more work on the hull done, doesn't look much but took a bit of time. Fitted the bilge keels, prop shaft housings and prop supports. More putty work then onto drilling all of the portholes out using a 1.6mm drill. Noticed here a couple of ports are missing but can't drill them yet. Need to get the ladder positions drilled first to make sure I drill the portholes in the correct position. Finally, went over the whole of the hull with 1200 grit sandpaper to get it all perfectly smooth. Now ready to start fitting some of the etch so until next time.... happy modelling..... Regards Alan Gandale attached the following image(s):
Its another step closer to getting it completed Alan. That is a lot of work having to sand something so large but its all the important steps to make sure you get a nice finish. Hope it continues well. Tony Happy Modelling
Thanks Tony, a long way to go but progress is progress.... Certainly a lot more work to building in plastic that I thought but great fun..... Regards Alan
