deck beams Options
cal
#1 Posted : 15 September 2011 11:48:00
hi fellow builders im just starting on issue 45 the destructions say use a strip of 1 x 6mm wood for the deck supports question is which issue do they come in i cant find them in any oft he packs i have already opened
#2 Posted : 15 September 2011 12:16:16
Its a misprint at step 4, the size is 1.5x6mm as per the strips supplied in 45 (noted in the parts list as 1.5x6mm)
cal
#3 Posted : 15 September 2011 13:37:23
cheers mr t, am i missing some thing but 5 planks dos't seem enough to do the whole of the lenth of the ship
#4 Posted : 15 September 2011 15:01:07
In 44 you should also have five 1.5x6mm strips = 10 and is enough to complete the deck beams in 45, also says the same in my diary build for 45
http://forum.model-space....aspx?g=posts&t=1846
This page was generated in 0.027 seconds.
