Joined: 23/01/2021 Posts: 3 Points: 12 Location: Scotland
name is Kris what my problem was i started building, and got too the instructions which says 'Yamato:Step-by-step 46' turns out im missing 1 little piece of The base of the bridge part 3. the question is too you modellers out there if yous can see this post and reply back too me please too tell me what issue it was so i can order that issue pack so i can 1 start building it again, il attach the picture too this post also because every time i email model space even with the picture they arent much help until i figure out the issue number, hense this post. thx Kris Kris Thain attached the following image(s):
Welcome to the forum Kris, sorry to hear you have a missing part. If you contact CS and say the part you require would be in Pack 4 they should be able to help you then. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
magpie1832 wrote:The part you require would be in Pack 4.
Chris thanks so much magpie, couldnt believe how quick of a reply iv gotten, if only i did it sooner rather than bombard modelspaces email team
Kris Thain wrote:magpie1832 wrote:The part you require would be in Pack 4.
Chris thanks so much magpie, couldnt believe how quick of a reply iv gotten, if only i did it sooner rather than bombard modelspaces email team looking at what the full kit i got a while go, i did order by guessing by ordering pack 4 and couple of others, iv got here but deffinetly dont see it inside, im pretty new with forums part side of things
Right now, your best bet might be ebay. Between lockdown, Brexit and Covid, shipping is an absolute mess. This applies more towards items entering the UK, as opposed to internally. Give CS a call though, and email DeAgostinicustomerservices@deagostini.comStay well, Mark
Kris, I've just sent you a PM....
