3 Pages <123
Magnifier 1/12 Ford Gt40 Options
kpnuts
#41 Posted : 25 January 2021 22:58:17
There is 1 other thing missing from this kit, there is no indicator stalk (which is also the main beam ) luckily its a very simple set up so easy to scratch build also the steering shaft is too long and protrudes too far into the cabin (unfortunately I don't have the equipment to alter that but if you had a mill you could)
#42 Posted : 26 January 2021 09:25:23
All slowly coming together now Ken. It's going to be lovely when it's finished.
I'm almost tempted to get another one myself...BigGrin
kpnuts
#43 Posted : 27 January 2021 21:03:51
Hi all more work on the GT40
kpnuts
#44 Posted : 30 January 2021 21:42:33
Hi all more work on this,ive made some of the many fuel lines.
I bought a tray to use as the base for it to sit on. Can you guess the setting im going to put it in.
CaptnBirdseye
#45 Posted : 30 January 2021 22:28:39
Rank: Superelite
BigGrin Very mice Ken. Makes a change to see a black GT40 ThumpUp
kpnuts
#46 Posted : 05 February 2021 21:41:04
Started work on the setting for this
kpnuts
#47 Posted : 07 February 2021 20:53:43
This is what happens when you know next to nothing about electronics i ordered the wrong switches they only turn the lights off if you keep them pressed, ive ordered some on off toggle switches hope that works.
kpnuts
#48 Posted : 12 February 2021 18:23:36
Got most of the decals on now, on the last leg now.
kpnuts
#49 Posted : 12 February 2021 22:55:05
I should just mention the one draw back with this kit is the steering will never work as the clearance under the wheel arches only gives you about 19 degrees from lock to lock, still a minor detail in my mind (certainly not worth paying 200 more quid for)
Guest (6)
3 Pages <123
This page was generated in 0.149 seconds.
