There is 1 other thing missing from this kit, there is no indicator stalk (which is also the main beam ) luckily its a very simple set up so easy to scratch build also the steering shaft is too long and protrudes too far into the cabin (unfortunately I don't have the equipment to alter that but if you had a mill you could) Ken's the name modeling's the game.
All slowly coming together now Ken. It's going to be lovely when it's finished. I'm almost tempted to get another one myself...
 Very mice Ken. Makes a change to see a black GT40
I should just mention the one draw back with this kit is the steering will never work as the clearance under the wheel arches only gives you about 19 degrees from lock to lock, still a minor detail in my mind (certainly not worth paying 200 more quid for) Ken's the name modeling's the game.
Guest (6)
