7 Pages «<567
William's Build Options
William's Build
#121 Posted : 09 February 2021 16:36:02
Quick one all,
As I near the end of planking the hall, I’m realizing that I haven’t tapered the bow and stern planks enough. As such, I’m going to have a gap in the middle of the hall. Any suggestions?
William's Build
#122 Posted : 09 February 2021 16:36:27
Picture attached
William's Build
#123 Posted : 09 February 2021 16:39:19
William's Build wrote:
Picture attached
Trying with an iPhone at the moment. One sec.
No chance of taking them off!
z8000783
#124 Posted : 09 February 2021 16:44:14
Groups: Unapproved
Quick one all,
I can't really see the problem in that pic but I'd say take them off and do them again.
William's Build
#125 Posted : 09 February 2021 16:49:01
Quick one all,
Not going to happen.... I just can’t bare to remove them. This process has been long enough! Any other suggestions? I was thinking about just filling it in with planks when I finally run out of space.
z8000783
#126 Posted : 09 February 2021 16:55:29
Groups: Unapproved
As I say, I can't see the problem in that pic. Just remove any offending planks from that point on.
If you are going to tile the hull then it won't matter at all. You probably won't even need filler.
William's Build
#127 Posted : 09 February 2021 17:06:35
My main concern is that there is more of a gap in the middle, so by the time the ends are complete there will still be a gap there. All good though I'll keep going. Not decided on the copper yet, I dont think you can buy the pack anymore no? I remember Stevo using copper tape or something though. I remember you from way back in 2014 by the way John!
Just had a look at your build diary but can't see any pictures? Were you one of the unfortunate chaps that lost them through photobucket? I'm guessing you made a lot more progress than me!
z8000783
#128 Posted : 09 February 2021 17:14:44
Groups: Unapproved
Yes, I can't believe how long I have been working on this build . . .
The pics are all there OK but there does appear to be a problem with people using Chrome. Try using Microsoft Edge or Fire Fox.
William's Build
#129 Posted : 09 February 2021 17:16:21
Ahhhh ok ill try now. In the meantime have you seen these? https://www.shapeways.co...ketplace?q=1%3A84+scale Know if anyone has used them instead? Im not overly impressed by the quality of some pieces that shipped with the kit!
William's Build
#130 Posted : 09 February 2021 17:49:56
A couple of updated shots of the workbench. Hard to believe I spent most of the build in a cupboard so far!
A particularly helpful tool has been the Dremel - recently upgraded to include a feed from my larger dust extraction system! :-)
7 Pages «<567
This page was generated in 0.170 seconds.
