C00lh4nd Options
C00lh4nd
#1 Posted : 14 February 2021 15:54:25
Rank: Newbie
Lubricant?
Completed Stage 54 front landing gear last week and have moved to fitting the jet inlets with the red covers. On finishing the install I "lowered" the front landing gear being a gentle as I could. Despite having used graphite on the main hydraulic ram the gentle pressure applied to moving the gear pulled screw out of the plastic part attaching the main pivot point for the gear to the body of the aircraft (Build 11, Stage 54 Front Landing Gear, part D072).
What have members done to lubricate these pistons around the model?. And how easy is it to get spare parts.
TIA
C00lh4nd
CaptnBirdseye
#2 Posted : 14 February 2021 17:03:17
Rank: Superelite
BigGrin Hi if you give Customer Services a call, quoting your order number, they can usually send out a replacement
#3 Posted : 14 February 2021 17:16:53
Further to the Captains post above, you will need to quote that you need stage 54 replaced and not just the part number.
CS will only send a complete stage. You should contact: 0333 240 1227 (8am - 5pm) from Monday to Friday and take a note of who you spoke to for reference.
This page was generated in 0.092 seconds.
