13 Pages «<89101112>»
Micks 1/200 battleship bismarck Options
#181 Posted : 20 February 2021 23:13:01
Looking good Mick.
Will end up a nice build with all the lights and movement. Well done so far.
Cool Cool Love Cool Cool
#182 Posted : 21 February 2021 01:15:12
Coming along beautifully Mick, lovely work....Drool Drool .. Eagerly looking forward to your next update..... Keep the pics coming....Drool Drool
#183 Posted : 21 March 2021 12:44:36
Hi thanks to all who looked in and left comments much appreciated.
Issue 99
Here we just fit another 15cm gun to the deck we got in issue 64,and put in the limit switch. Cheers mick. BigGrin
#184 Posted : 21 March 2021 12:52:35
issue 100
First of all fit another hull plate, one with the black and white stripe, then just 4 bits of etch handrails to glue on the aft superstructure, we also do electronic test on all the mid superstructure, this includes second main turret, all the lights and both radar units, mine all worked as should for now, cheers mick. BigGrin
#185 Posted : 21 March 2021 12:56:21
Issue 101
Here it's just fit the motor to the 15cm gun just fitted. Cheers mick. BigGrin
#186 Posted : 21 March 2021 13:05:34
Issue 102
Here we just screw the deck on the aft superstructure main part, then screw the aft superstructure to this.its at this point I decided I did not like the colour of the decks so I repainted them with a brown wash, bin alot easier if I'd decided to do this at the beginning, instead of having to do it around everything now. Oh well. I'm going to weather the rest of it now, only lightly, as she not that old when sunk. Cheers mick. BigGrin
#187 Posted : 21 March 2021 14:52:26
Coming together very nicely Mick.Love Love
#188 Posted : 02 May 2021 15:16:56
Issue 103
Here we get another hull plate to fix, then it's just a few bits of etch handrails, cheers mick. BigGrin
#189 Posted : 02 May 2021 15:28:03
Issue 104
First of all another hull plate to fix, sorry pic is from inside but it's impossible to turn her upside down now,then we screw the 2 parts of deck together, then screw the rear superstructure to the deck. Then it's add handrail, and some pipes to the rear superstructure, then add the etch boat supports, and walkways plus couple ladders.BigGrin cheers mick.
#190 Posted : 02 May 2021 15:30:15
Hi sorry forgot to upload pic of boat supports. Cheers mick.
#191 Posted : 02 May 2021 15:51:40
Issue 105
There a lot of parts in this issue, first of all we fix another hull plate, then glue in splinter protections the lifebouys storage cylinders and lockers, then it's the paravanes fire hoses and ladders on the deck. Ships bell a winch for the mainmast, and few parts in front of the hanger doors, cheers mick. BigGrin
#192 Posted : 02 May 2021 16:12:38
Issue 106
Another busy one this fit another hull plate, add binoculars then make up 2cm flak guns from etch add there bases, then few more bits of splinter protection couple small lockers 2 small pipes to front just behind main turret. Couple more lockers to superstructure sides. Then add the boat supports, had to fiddle with these a bit to get them perfectly level for the catwalk to sit true, I built up the anti aircraft station complete off the model, not doing it bit by bit as instructions, also there is a small locker behind this part which is easier to fit first, then build up the 8 3.7cm guns I painted the barrels on mine gun metal, then 4 go on the aft superstructure and 4 on the bridge section of superstructure, then finally make up the 4 rope coils and fix to deck where shown, that's me caught up again till next time cheers mick. BigGrin
#193 Posted : 02 May 2021 22:55:37
She's really coming along very nicely, great to see.....Drool Drool Drool
#194 Posted : 03 May 2021 18:26:07
Looking very good Mick.
Cool Cool Cool Cool Cool
Keep it coming.
#195 Posted : 05 July 2021 11:36:41
Hi bin a while since worked on this but life kept getting in the way so hardly done any moddeling in last couple months,
Issue 107
First of all we attach another hull plate then assemble the aft signal bridge, and glue this in place, then bend up another ladder and fit this in. Cheers mick. BigGrin
#196 Posted : 05 July 2021 11:44:06
Issue 108
Fix another hull plate in, then assemble the last 15cm gun and fix this in, then just another rope reel is added to the aft superstructure. Cheers mick. BigGrin
#197 Posted : 05 July 2021 11:47:51
Issue 109
Here it's just fit the motor and limit switch to the underside of previous 15cm gun. Cheers mick. BigGrin
#198 Posted : 05 July 2021 11:52:10
Issue 110
Here we just assemble the barrels and recoil unit for the 3rd main gun turret. Cheers mick. BigGrin
#199 Posted : 05 July 2021 12:03:27
Issue 111
First of all we attach another hull plate, then it's assemble the main turret housing cheers mick. BigGrin
#200 Posted : 05 July 2021 12:13:03
Issue 112
First of all we attach another hull plate, add the details to the 3rd main gun turret then add the turret Base and end plate, place the barbette in the aft deck, then put the gun in and fix via the white cog at bottom making sure the arrow on the cog faces aft. Working underneath is a pain with all the details on top. Cheers mick. BigGrin
This page was generated in 0.476 seconds.
