Joined: 11/12/2020 Posts: 15 Points: 51 Location: Birmingham England
I am having trouble getting a good paint finish on the dashboard vent Grill, which I think is because of the preparation of the brass etching. I have cleaned the brass with all sorts of cleaner even Trichloroethane which was a brilliant degreaser and cleaner (so good that it has been banned) I then used AK interactive Photoetch Burnishing fluid but even after a couple of hours in the fluid still wipes off. Has anyone any suggestions please Brian Whitworth attached the following image(s):
Joined: 11/11/2015 Posts: 278 Points: 807 Location: Minneapolis, Minnesota USA
What kind of primer and paint are you using? Also are you brush painting or spraying? Best Regards, Ron
On the bench: DeAgostini '67 Ford Shelby Mustang, Hachette Space Battleship Yamato 2202, Agora Models T-800 Terminator Finished builds: DeAgostini Toyota 2000GT In the Stash: Losing count...
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,868 Points: 17,756 Location: ipswich
There used to be a Humbrol paint called 'Makes paint stick'. It was amazing on just about anything. I used it long ago to prime a brass live-steam garden railway engine. Worked a treat but Humbrol must have changed the name as I can't find it. Maybe a bit of searching will bring it up.
This is what I do. I go over the part with either a Scotch Bright pad or some #0000 steel wool. Clean with 91% Isopropyl Alcohol Then I prime with Rust-Oleum self-etching primer. It has a mixture of acid and zinc in it to help it stick to the brass. You should be able to find it in any hardware store or automotive shop. https://www.homedepot.co...r-Spray-249322/202097278Best Regards, Ron
Joined: 05/03/2017 Posts: 531 Points: 1,710 Location: Midlands, UK
Not answering your question but I like this part, may I ask where you got it from? Building: Ghostbusters Ecto-1, Ford GT40, Gone in 60 seconds Eleanor mustang, Shelby Cobra Complete: R2D2, Red Bull RB7 RC, Battleship Bismarck, Shelby GT500 'super snake'
Thanks for all the answers and advice. The reason I wanted to leave the vent in a blacked condition (not painted ) is because the slots in the center section are only 0.45mm wide and can easily become clogged with paint hence loose the definition. the question as to where I got the item from I will answer in a later post as I am trying sort something out at the moment. but I will answer very soon. Thanks again for the response
Hi Brian,
The PE looks great! Search for a model railroading product called “Blacken-it” which will do the trick.
Should you go into production, I’d like to remind you that sales are not permitted on these forums, save through a 3rd party such as eBay. I’m more than happy to permit an eBay link, but please, NO personal sales. I get grumpy, and start airlocking members when that happens.
Thanks!
Thanks Admin. I commissioned the dashboard vent as a one off which cost a hefty sum only to get 20 of them on a sheet of brass so I will be setting up a E bay account to do just that to offset the layout. I had read the rules on selling on the forum.
Brian Whitworth wrote:Thanks Admin. I commissioned the dashboard vent as a one off which cost a hefty sum only to get 20 of them on a sheet of brass so I will be setting up a E bay account to do just that to offset the layout. I had read the rules on selling on the forum. Hey Brian, I apologize if I came across as lecturing. It’s an old problem that rears it’s ugly head occasionally, and it’s better to remind everyone else, in the event someone reading it may have missed the policy. (Send the eBay link PM before you post it......  ) Stay well, Mark
I had no idea it was a custom part you had made, I thought you had bought it from somewhere Building: Ghostbusters Ecto-1, Ford GT40, Gone in 60 seconds Eleanor mustang, Shelby Cobra Complete: R2D2, Red Bull RB7 RC, Battleship Bismarck, Shelby GT500 'super snake'
