4 Pages <1234>
Dolls House Options
Mustang
#41 Posted : 02 March 2021 18:16:12
Next hiccup is the windows when sitting on the walls sit at an angle, can't even see the bubble
Holding the bottom out.
So do I increase the bottom slightly or just stick them on Confused Confused Confused
To build:-
Mustang
#42 Posted : 02 March 2021 18:18:04
Next hiccup is there is no cut out in the front to see in..
So do I cut out the inside of the wall so you can see in.
To build:-
Mustang
#43 Posted : 02 March 2021 18:19:48
If I do cut out the wall section and increase the bottom of the window unit I have to make three of these.
To build:-
Mustang
#44 Posted : 02 March 2021 18:21:36
So what do you think.
Hiccups
Two or three windows. Confused Confused Confused
Increase the bottom slightly. Confused Confused Confused
Add internal wall sections. Confused Confused Confused
To build:-
#45 Posted : 02 March 2021 18:31:22
Hi Mustang,BigGrin
So, my thoughts to cure the issues in one go.
Mark the positions of the windows as tight as you can to the sides and cut through the panel. This should allow you to tilt the top of the windows back to make the outer surface perpendicular and allow sight through the windows. Glue the bottom edge and sides to hold in place, but you may then need to do a small filler job over the top of the windows and a small trim job on the inside of the panel, or build up on the inside.
Hope this gives you some ideas of how to solve the problems.Blink Blink
goddo
#46 Posted : 02 March 2021 18:51:25
Definitely three dormer windows..... in my humble opinion of course!
The room decorations look fabulous. When can I move in?
Chris
Mustang
#47 Posted : 02 March 2021 19:14:37
Hi Chris, anytime you like LOL LOL
To build:-
Mustang
#48 Posted : 02 March 2021 19:17:06
Hi Derek,
I did think about doing it that way, but my concern would be that once you’ve cut the shape at the top to allow that section to slide in the inside would need more work. You would still need to fill in the sides but you would then be left with the curve on the inside needing a lot of filling or wood shaping.
To build:-
#49 Posted : 03 March 2021 10:35:02
Mustang wrote:
Hi Derek,
I see what you`re saying, so the only other way is to pack out the bottom of the window to get them vertical and fill the gap down the sides with a triangle of wood to help adhesion. Then you would only need to cut out a rectangle for viewing through the window.
Its very strange that the holes for the windows were not pre-cut. Confused
Confused
Just another thought, (that`s two in the same day Blink ) If you were to tilt the window back through a fully shaped hole, the thickness of the roof panel will take up some/maybe all of the amount of the window that needs to be recessed. That could explain why the windows don`t sit straight on the outside of the roof.
skyfire
#50 Posted : 03 March 2021 12:46:13
From memory I just cut two holes where I wanted the windows to sit and then glued them in place. I pretty much ignored the instructions for the roof with the one I built and did it my way, which worked out in the end.
Mustang
#51 Posted : 04 March 2021 22:43:37
Chimneys made....
Confused something missing Confused the chimney pots LOL I'll add them.
To build:-
Mustang
#52 Posted : 04 March 2021 22:49:13
So window hiccup sorted, I'll be doing three as it does look a lot better...
And sorted the angle out, I did look at cutting the shape out on a spare piece derek but the amount the window as out was more then the thickness of the plywood so I would still have needed to fill the bottom out. So I just built the bottom out instead.
Now all I have to do I get the nerve to cut out the wholes in the front of the roof, would mind so much but the flysheet already has the wallpaper on the inside as the manufacture stuck them on.
To build:-
#53 Posted : 04 March 2021 23:51:27
Happy to see you have a satisfactory solution.
Cool Cool Cool Cool Cool
Gently does it then with the cut outs. BigGrin
Mustang
#54 Posted : 22 March 2021 17:38:11
Hi all,
So heres the latest instalment..
All 3 windows added and I've also added a small window sill.
To build:-
Mustang
#55 Posted : 22 March 2021 17:40:44
Next I added the roof tiles.
Then added the roof windows.
From inside.
None of the windows come with perspex so I brought some to add window pains.
To build:-
Mustang
#56 Posted : 22 March 2021 17:43:40
The main part of the house is finished just waiting for some paint to dry on the summer house section.
Red door because the girls favourite colour is red. BigGrin
To build:-
#57 Posted : 22 March 2021 17:57:12
Excellent progress and well done with the dormer windows.
goddo
#58 Posted : 22 March 2021 20:57:46
Very smart Ian.
A good job done on those extra roof windows.
When cabn I move in?
Chris
#59 Posted : 22 March 2021 23:48:38
Looking really good, your efforts are certainly paying off.... Drool Drool .. Very well done....
skyfire
#60 Posted : 23 March 2021 08:46:32
Amazing bit of work on the house. It looks fantastic. :)
Guest (17)
4 Pages <1234>
This page was generated in 0.339 seconds.
