Motor Modeller - Cars
Ford GT
Modified Ford GT Build
Joe Bergman Pack 12 Personal Warning - Will Show Sectional Build When I do Pack 12
 Rank: Beginner Level 3   Groups: Registered
Joined: 01/02/2018 Posts: 25 Points: 57 Location: New York City
PLEASE FOLLOW SOME ADVICE HERE.
At Step 47-1 I WOULD REMOVE THE CALIPER AND BRAKE ROTOR ASSEMBELY FROM THE HUB. Put the screw and wheel nut in a storage cut with the hub and tire.
Personally, I feel if you install the tire when the when the from wheel assembly is attached.YOU WILL CAUSE DAMAGES TO THE SUSPENSION installed in issue 11.
Follow the process of Step 48 of installing the tire on the hub.
This is now up to you.......
1) You can install the tire on the caliper with the screw and add the wheel nut, or you can wait to get both front end tires on together and keep the front end balanced.
OR
2) After you have installed the body.
The choice is yours.
THINK AND MENTALLY ENGINEER THIS PART OF THE BUILD.
Until Next Time
Thanks Joe, for mentioning this.
It’s utterly dumbfounding they propose to have builders do it this way.
Stay well,
Ford GT
