Fiat, Pack 7 Options
admin
#1 Posted : 08 March 2021 04:57:14
Pack 7 Stages 31-35
Stage 31 Build the wheel
Stage 32 Fitting the wheel
We just built the wheel in Pack 6, so put the wheel together and mount the wheel, the brake plate, brake line and the hub.
Stage 33, Left engine cover
In this Stage we will build one of the engine covers and install it. Put the cover, 33A in position and secure it with 4AM screws. I used a cross pattern and left the screws a little loose until all four were started, then tightened them all. The rear wall will be set aside until later.
Stage 34, Left rear wheel arch
We’ll first put the regulator, 34C to the wheel arch, 34A with 1DP screw.Mount the wheel arch with 2BM screws to the chassis. Mount the side engine cover 34B with a DP screw.
Stage 35, Engine top cover
The engine top cover will be assembled and set aside until later. Install the two air inlet covers with 2DP screws each. We have several stashed assemblies that will be used later.
admin attached the following image(s):
This page was generated in 0.025 seconds.
