I can't seem to get the proton torpedo bay to fit properly. The detail strakes on the side of bay seem to be binding things up. Any experience or recommendations?
I haven’t got to this stage, so can’t really help. If you can show some pictures, it may help to see what is happening. I’m sure someone will be able to help you. Mark Regards Markwarren (Mark) Admin
It doesn't look like these parts were even made to go together...
Joined: 25/03/2011 Posts: 1,027 Points: 3,075 Location: Lincolnshire
Hi Shinden, I know this might sound obvious, but have you taken the parts off and tried reinstalling them to see if they fit better Regards Glenn
Silent_Running wrote:Hi Shinden, I know this might sound obvious, but have you taken the parts off and tried reinstalling them to see if they fit better Regards Glenn Hi Shinden Further to my earlier post, I’m trying to establish whether this a fitment issue or faulty parts? Please can you pm your details to me please including: Subscription number Full name Full address E-mail Telephone number I Will then pass it to Admin who will look into it for you. I hope this helps you and look forward to your reply! Kind regards Glenn
Yes, I took the torpedo bay apart and re-assembled it. It looks to me like the shell doesn't fit the model. PM'ing as requested.
shinden252 wrote:Yes, I took the torpedo bay apart and re-assembled it. It looks to me like the shell doesn't fit the model. PM'ing as requested. Hi Shinden, I have sent a pm to your inbox. Kind regards Glenn
Hi Shinden, After consultation with Admin, this is a fitting issue, not a fault. If you click on the link I have posted and go to post 15 this will provide you the information you need to fix your issue. https://forum.us.model-s...sts&t=33811&p=1
Kind regards Glenn
Ok, so I tried all of the above and it still doesn't fit. Anyone have any luck with the torpedo bay?
Disregard. Fixed it. Just put some upward force on the nose and that shifted the structure enough to make it fit.
