Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,145 Points: 21,742 Location: Northamptonshire, England
Stunning work Kev, The wash certainly make all the difference, looks so real. Mark Regards Markwarren (Mark) Admin
Joined: 25/03/2011 Posts: 1,027 Points: 3,075 Location: Lincolnshire
Fantastic work Kev, I’m loving the look of the cockpit it’s super. It just shows the value resin brings to the table
Well I`m very impressed. This has made it into the category of "Stunning"  Keep up the good work. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Nice details on the cockpit and the hydraulic lines. That padded seat seat looks very good. Did you use a semi gloss or Matt paint on that? Malc.
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,496 Points: 16,640 Location: ipswich
Amazing work here. That cockpit certainly looks comfy.
It looks like a WW2 fighter plane cockpit  amazing work Kev Regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Truly outstanding Kev, the work done on that cockpit really makes it stand out..... Wonderful skills..... Regards Alan
Gandale wrote:Truly outstanding Kev, the work done on that cockpit really makes it stand out..... Wonderful skills..... Regards Alan
Thanks Alan, as always I really appreciate any comments from you, and yes, you're right, it really does make the cockpit stand out and I think the padded leather seat and overall blackness of it all will really draw the eye to this area of the model once it is surrounded by that beautiful deep metallic blue bodywork - which should happen quite soon!
Kev
Per Ardua Ad Astra
Hello all,
Took a bit of a break from posting on the forum and it's been a while since I updated this build. I have however been working away at it whilst absent so time now for an update.
The next stage was to prep, paint, decal and finish all of the body panels prior to eventually gluing the engine/transmission assembly to the chassis.
First up, a photo of the basic body parts all of which are cast white metal, except the nose cone which is cast resin. The photo below shows the parts cleaned up and ready for paint:
Prior to painting the nosecone I needed to cut some of the kit supplied brass mesh to shape to fit inside the nose cone which acts as a debris barrier on the real car and protects the main coolant radiator.
The photos below show the mesh cut to shape, then immersed in 'Krick' brass blackener to darken it and then test fitted inside the nosecone. At this stage it is not permanently fixed in place:
With that done, the body parts were primed and painted with several thin coats of the 99.9% accurate 'Zero Paints' Eagle T1G metallic blue paint. The photo below shows this process completed, the paint being quite dull at this stage but it will 'pop' when the clear coat is added after the decals have been fitted:
Decals and clear coat added:
I then set about adding the various suspension fittings and lower front arms. The fuel filler caps and breather pipe connections were also added to the top of each side panel:
The nosecone was finished and the various rivets, brake cooling fins and the the mesh finally fitted:
The next job was to fit the windscreen, anti-roll bar and mirrors, etc to the upper cockpit shroud. The two black electrical boxes that sit within the anti-roll bar are pretty basic and research shows that there are various wires and cables attached to these, so I scratchbuilt some tiny fittings and added the extra cabling as per my reference photos. A nice improvement I think. The ends of the wires were just tucked inside the shroud as they won't be seen when the bodywork is finally all fitted:
Thought I'd just put all of the various panels together on the main chassis tub to get an idea of what this will look like when completed. Note that the panels are only resting in place here, so there are gaps and misalignments to the central white stripe but they will all correct themselves when the panels are permanently fitted in place later:
That's it for this update. Ready to glue the engine/transmission permanently to the chassis next, then it's on with the front and rear suspension, driveshafts and hubs.
Kev. Per Ardua Ad Astra
Stunning work Kev. Nice to see this one coming together.
Rank: Administration  Groups: Administrator, Administrators, Forum Support Team, Global Forum Support, Global Forum Support Team, Moderator, Official Builds Joined: 24/08/2009 Posts: 1,940 Points: 5,832 Location: UK
Glad to see you back! The Eagle is looking stunning. There is something so appealing about the contrast between that deep, rich blue, and the white markings…
If you are (or anyone reading this) are on FaceBook, I’ve just started a group dedicated to the MFH 1/12 Moby Dick Porsche 935/78. I’ve got a small group build going, but anyone is welcome!
Best,
Great stuff again Kev good to see you back on the forum. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Beautiful work Kev, modelling at its finest.  The colour is is superb and the detail is stunning. Looking forward to your next instalment. Mark Regards Markwarren (Mark) Admin
That's looking stunning Kev. Such a beautiful car and you're making a brilliant job of it. Malc.
Stunning work throughout Kev and so pleased to see you posting up updates on this one again...... Keep the pics coming..... Regards Alan
Hi Kev, I have only just caught up with this build and it looks as though you are making a great job of it. Look forward to seeing more updates. Chris
Sorry for the delay in replying to your kind comments guys but they are always appreciated. Just been very busy with life at the moment but have also managed to get some more done to this since my last update and will post more sometime in the next week hopefully!
I have also, earlier today and after a lengthy search, finally managed to acquire the MFH 1:12 'Standing' driver figure of Dan Gurney for this:
https://www.scalemates.c...standing-figure--953351
It is on special order through 'Hiroboy' and will be coming from MFH in Japan. I'll post pics of the contents as soon as it arrives or with my next build update, whichever comes first.
The car kit that I have does supply a seated driver figure of Dan Gurney, but I wanted a standing figure next to the car.
KevPer Ardua Ad Astra
Hi Kev, Good to hear from you, I know you do get very busy with fab painting and have to put modelling to one side, I think the Dan Gurney figure will look the part after you have put your art skills to it, looking forward to seeing that finished. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
