Fiat, Pack 11 Options
admin
#1 Posted : 26 March 2021 03:43:50
Pack 11, Stages 51-55 (shorter and, wellllllll… sweetish…..)
Stage 51; Left side inner trim
Mount the left inner trim with 3CP screws. Place the roof cover mount into position and secure with 2CP screws.
Stage 52 ;Right side inner trim
Mount the right side same as the left. Install the left front hinge as shown with a GP screw.
Stage 53; Boot opening lever
Join the boot lever and the boot hinge with a DP screw. Put the other roof cover on as shown with a GP screw.
Stage 54; Front bulkhead
Mount the lever hinge to the bulkhead with a KP screw from the underside. I decided to put the right hinge cover and the roof cover front hinge together, but I will tape it and the mounting screws to the Caravan top until the other front hinge is to be mounted in the next Pack.
Stage 55; Right front seat base
Build the right seat base as shown. Pack 11 is complete.
admin attached the following image(s):
This page was generated in 0.026 seconds.
