2 Pages <12
Issue 57 parts incorrect length Options
z8000783
#21 Posted : 17 September 2011 18:39:12
Groups: Unapproved
Er ... yes, that's correct, it is their customers from whom they will recoup the costs through higher prices.
John
Rum Runner
#22 Posted : 17 September 2011 19:17:57
Rank: Beginner Level 3
Not having got as far as issue 57 in my build I had not yet opened up the issue yet. On checking I find I too have the short 240mm strips instead of the 300mm size, will have to contact CS on Monday for replacements.
Thanks for the heads up on the problem
John
f1marshal
#23 Posted : 18 September 2011 15:05:40
I just checked my issue 57 and found i also have 240mm instead of 300mm i will contact cs tomorrow to get this rectified
Paul
Current builds:
1/24 Spitfire
1/48 Apache Longbow
Titanic Lifeboat
tf5600
#24 Posted : 18 September 2011 22:07:33
just checked issue 57 mine are to 240mm will contact CS tomorrow
ferret
#25 Posted : 22 September 2011 17:06:04
Just to alay fears, the 240mm length of these strips should be okay.
The five 1.5x6mm strips (noted as 300mm long) are used in issue 58 (step 1 page 12) to make the poop deck beams.
The longest poop deck beam should be no longer than 120mm long, and because it is double width laid, one strip 240mm long should be long enough to span the poop deck at the point indicated for the longest beam.
The remaining three beams are shorter spans, and therefore the 240mm long strips are more than adequate, (also being double width laid).
In effect, just four strips at 240mm long is enough to complete the task of the four poop deck beams, and leaves one strip remaining from the total of five supplied.
#26 Posted : 22 September 2011 17:51:57
Phew!! Thanks Mr.T, that's a great worry off my mind...ThumpUp
willie
#27 Posted : 22 September 2011 20:49:02
i said that a few times but they need you to tell them i have one 240mm leftHuh
#28 Posted : 22 September 2011 21:45:52
Which from what I can gather is a spare
2 Pages <12
This page was generated in 0.379 seconds.
