Deagostini Jaguar E Type Electrics Batteries??? Options
Steve56
#1 Posted : 28 March 2021 13:12:41
Rank: Newbie
I am at the stage of electrics in this model.
You would think at a cost of almost £900 it would tell you what to use battery wise for the electrics, but no Blink
Has anyone found out what to use?
I have searched other forums and not found the answer
Cheers
Steve1701
#2 Posted : 28 March 2021 13:39:01
if i remember correctly, it was three LR44 button batteries.
colin frayling
#3 Posted : 30 March 2021 17:14:56
Rank: Newbie
Hello Steve
Ref batteries on the Jaguar E Type Stage 13 says install an A23 type. They seem to be readily available Duracell or Energiser I have seen but they are too long to fit in the open box provided in the sump. I will try a photographic shop when they reopen. I find this all rather perplexing.
I would appreciate any guidance that anyone can provide
Colin Frayling
Mustang
#4 Posted : 31 March 2021 08:38:44
Hi Steve, the batteries you need are LR44 button cell batteries.
These will fit inside the sump of the model.
Just a link to show you the type, but there are other manufactures types.
https://www.amazon.co.uk...id=1617176237&sr=8-4
To build:-
Mustang
#5 Posted : 31 March 2021 08:39:48
By the way it tells you in issue 100. Confused
To build:-
sdeccles81
#6 Posted : 05 April 2021 20:30:20
Rank: Beginner Level 1
I have wired in a micro usb socket that sits hidden at the back of the chassis, a 5v 1000mah phone charger works just fine. I did the same with my Mustang build, though this time it has been added at the start.
This page was generated in 0.387 seconds.
