Soldering iron advice Options
semaj
#1 Posted : 29 March 2021 16:50:23
Hi all, I'm wanting to make some changes to the leds on various models I have (such as the shelby mustang and ecto 1 as an example), mainly swapping the headlight leds for more accurate looking ones (I really don't like the modern xenon blue look on a vintage vehicle).
I figured it would be best for me to buy a soldering iron/soldering Station in order to swap them properly. As I learn I may begin to become more adventurous so I want something decent, and ideally something I can buy from amazon.
Can anyone recommend what is really good? Is adjustable temperature better or required? Changeable tips? Ideally I want to buy 1 that is proper and decent to last rather than just something 'cheap'. What other things should I look for with a soldering iron?
What about the actual solder it's self, as I see many types available - leaded, non leaded, some incorporating flux some not and requiring powders and things, and different thicknesses too.
Once I have said equipment, how do I know what temps required in order to use it?
Where do I start with any of this? The last time I did any soldering was over 22 years ago at school, back then I just used what the teacher gave me....
Any advice would be greatly appreciated
Building:
Complete:
#2 Posted : 29 March 2021 17:12:25
I would recommend getting a digital soldering station.they heat up much quicker than a regular soldering iron and you can adjust the temperature to match your solder.They usually come as a ikit with a few tips and tinning powder and tip cleaners.
I just bought this one and it works great. I found that the cheap soldering irons caused nothing but frustration when I was learning how to solder because you never knew how hot the tip was.
https://www.amazon.com/g...7_s00?ie=UTF8&psc=1
I generaly use lead free rosin core solder.
Here is an excellent guide to soldering
https://www.makerspaces....to%20health%20concerns.
PS dont forget eye protection and adequate ventilation when soldering.
#3 Posted : 29 March 2021 21:11:27
Hi Semaj, BigGrin
You are liable to get lots of different opinions on this question. Blink
Here`s my opinion:
Along with a soldering iron if you are going to swap out components, I`d suggest a combo of soldering iron and heat gun. The heat gun is a useful addition so you can insulate components and their associated wires with heat shrink tubing.
You can buy soldering irons and heat guns as separate units, but you`ll most probably save money if you buy a combo unit (All in one)
Here is a link to one example:
https://www.amazon.co.uk...05vdExvZ0NsaWNrPXRydWU=
semaj
#4 Posted : 29 March 2021 21:57:13
Thanks derbyvet, that looks pretty good, I'll have a look for a uk version and check it out a bit more. That was exactly my point about cheap ones not being very good.
Thanks delboy, that's some piece of kit there! It bit pricier than I was expecting and looks a bit out for my needs.
I already have a bosch heat gun from decorating and paint stripping, so maybe I could use that for shrink wrap on a low setting?
Lots of opinions is what I'm after as at least it steers me in the right direction rather than going totally blind.
Building:
Complete:
semaj
#5 Posted : 29 March 2021 23:38:12
I've seen this one on amazon and it looks to have pretty decent reviews and things. Price doesn't seem to bad and it has a pair of 'helping hands' clips on it that look mighty useful. Also comes with a reel of solder too.
https://www.amazon.co.uk...bc_GNKZE1YEENJQATV6A1V2
What do the 'experts' think to this? Is it a no go? Or wold it be a good starting point for a few years?
Building:
Complete:
#6 Posted : 30 March 2021 01:12:11
I dont know the brand, but it has some good reviews.I like the extras too.The sucker tool is great for removing solder.
semaj
#7 Posted : 30 March 2021 12:49:03
Thats what drew me. It looks a decent bit of kit to get started with and a lot of useful extras with it too.
Building:
Complete:
CaptnBirdseye
#8 Posted : 30 March 2021 15:19:47
Rank: Superelite
BigGrin Looking at the reviews, for forty quid it's got to be worth a punt, hasn't it?
#9 Posted : 30 March 2021 21:03:39
Looks good to me too. ThumpUp
When using the heat gun you have, put on the lowest setting as you said and gradually move it closer till it takes effect. If its too fierce, then maybe a need for a more controllable version.
Good luck with the projects that need the reworking.BigGrin
semaj
#10 Posted : 30 March 2021 21:12:56
Thanks for all the help folks, I really appreciate it!
One more thing, with solder, I'm looking at buying solder that has roisin core. Am I right in thinking that it contains flux already and therefore I don't need to add flux to the project 1st? Or is it a good idea buying a small tin of flux wax too?
Building:
Complete:
#11 Posted : 30 March 2021 21:55:11
Correct.However I will use a flux pen especially when soldering to a PCB as it helps the solder to flow onto the board.
Dont forget to tin your soldering iron tip too before and after each session and keep the tip clean .When the tip gets pitted replace it.
semaj
#12 Posted : 30 March 2021 23:06:20
Ahh cool, so for now, just soldering leds tonwires I'll be fine with just the solder. Got it 👍🏻
Thanks for the tips too. I've spent a fair bit of time watching videos and things on YouTube. I've placed my orders so a few days time will be time to start learning
Building:
Complete:
This page was generated in 0.358 seconds.
