19 Pages <1234>»
Official HMS Bounty Build by tenderfoot Options
Medric
#21 Posted : 30 March 2021 20:23:08
My heart sunk for you. That is my worst fear. This really is a very advanced level model. Just in the early stages has that become apparent to me. I'm glad that you have figured out the fix. I will learn from you and proceed with my build at an increased level of caution and scrutiny. I've already botched the fairing on one rib and have to completely re-do it.
"It is far better to dare mighty things than to take rank with those poor timid souls who know neither victory nor defeat ".
Theodore Roosevelt
#22 Posted : 31 March 2021 00:05:05
I've yet to come across someone building these kind of ships who hasn't made an error somewhere in the construction process. At least you spotted the problem before you were too far into the build and no doubt other errors will be made as you progress.... But, correcting any errors is also part of this wonderful hobby and publishing them helps us all in our quest in gaining knowledge and experience..... Well done, keep posting up and I'll keep following.....Cool Cool
tenderfoot
#23 Posted : 31 March 2021 21:12:48
Publisher Medal: Featured Build of the MonthBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
Groups: Official Builds, Registered
Thank you all for the kind words, advise, and support. I'm enjoying this Build Log thingy more than I thought I would and that is mostly due to you excellent folks hanging around - looking forward to meeting others in this forum as well.
COMPLETED:
• HMS Victory (DeAgostini Subscription) - if you haven't got it, get it...what a beautiful build. This was my first attempt at this stuff and what a great experience. The instructions were spot on for those new to the hobby.
• HMS Bounty Admiralty (DeAgostini Subscription) - View the build diary.
IN PROGRESS:
• USS Constitution (DeAgostini Subscription) - View the build diary.
IN NEED OF MY LOVE AND ATTENTION:
• HMS Sovereign of the Seas (DeAgostini Subscription) - promise myself I will get to this after I finish the USS Constitution and the HMS Bounty. Need to maintain balance in my marriage.
tenderfoot
#24 Posted : 31 March 2021 21:18:49
NOTE: This is a very small mod. I wanted to go with a lighter wood for the mast mounts. The ones provided in the kit are perfectly fine.
Mentioned earlier that I jumped ahead to the skiff whilst I await the next issue. I noticed in the instructions for Month 9 there was a photo of the completed skiff and I didn't really like how dark and monotone everything was. This is why I decided to lighten things up a bit - I also like contrasting colors of wood on a build and want to incorporate some of that into this.
First up were the mounts for the masts. Nothing wrong with the ones provided with the kit, I just wanted to make them lighter so they were actually visible to someone viewing the model. Items this teeny are nearly impossible to handle and shape individually, so I decided to take a piece of 4x4mm and carve them out. I made three of which two were acceptable. Once I had them worked to my liking I cut them free and glued them in place. I also drilled the 2mm hole prior to cutting them free. Note: a clean, sharp blade is needed for this. I tend to be very frugal and stretch a blade as long as I can. However, the smaller the bit, the more important it becomes to have a new blade.
tenderfoot attached the following image(s):
COMPLETED:
IN PROGRESS:
tenderfoot
#25 Posted : 31 March 2021 21:28:56
NOTE: This is a small mod. I wanted to go with a lighter wood, in this case it was something I had laying around and I believe it is boxwood.
I also decided to deviate on the floor boards. I didn't really care for what the instructions called for which were boards that taper from 3mm in the center to a point at the end. Plus, these boards ran nearly the length of the hull. I don't know if that is accurate or not to what would really be done, but I didn't figure there were many instances where a boat builder would bring a board to a fine point - just doesn't seem like it would hold up in the real world.
I took some .5x5mm planks I had laying around and ripped them down to 3mm. I then took some artistic license in where I wanted the floor boards to start and end. Again, went with lighter wood to add some contrast.
COMPLETED:
IN PROGRESS:
tenderfoot
#26 Posted : 31 March 2021 21:35:05
The transom was another instance of "need clean sharp blade". The laser cut piece needs to be modified per the instructions. However, get a bit too happy with the knife and it could go south really quick. Took my time here - "measure twice, cut once". However, this time was a bit more like "measure twice, cut, measure twice again, but a little more...repeat". End result was a near perfect fit. Kept a towel nearby to wipe the sweat from my brow as I surgically removed the needed bit without accidentally hacking off the little pointy parts.
COMPLETED:
IN PROGRESS:
CaptnBirdseye
#27 Posted : 31 March 2021 21:40:35
Rank: Superelite
BigGrin Agree 100% about the floorboards. It's like with the decking, where they 'joggled' the planks at a 45 degree angle half the width of the plank so they didn't come to a point. Yep, definitely much better ThumpUp
Here's a link to Modelshipworld, that shows what i mean:
https://modelshipworld.c...-how-to-do-deck-edging/
By the way, for your first build diary, you're doing an excellent job. Keep it up.
Gray
tenderfoot
#28 Posted : 31 March 2021 21:40:38
Then came some easier steps. Cleaning up and glueing in place the seats and whatever you call those pieces at the bow and the stern. Felt good after this as it really strengthened the ribs. You can see in the photo where one rib is a bit out of kilter, but it has enough flex that I can adjust that when I add the first planks. I also noticed there is the slightest bit of twist to the keel so I need to remember to deal with that when I plank as well. The instructions call for only the first couple strakes at the top but I may decide to fully plank one side just to help give it more of that "boat" look. Again, looking at the final product in the instructions and the skiff just doesn't come across to me as a skiff. I will think on it further.
COMPLETED:
IN PROGRESS:
Medric
#29 Posted : 31 March 2021 22:59:17
Great pictures ! They show the work well. I like how you've modified things a little here and there. You're giving me some ideas to ponder. Just curious, have you done any of the work on the cannons and culverins ? I thought I would save them up and do them all at the same time. Also, I watched Master and Commander ( for the umpteenth time) last week and noticed that a culverin on HMS Surprise looked pale flat green. Went out today and bought a small bottle of Tamiya Gunmetal. Hope it looks okay.
Theodore Roosevelt
tenderfoot
#30 Posted : 01 April 2021 01:11:12
Medric, we are birds of a feather, my friend. I too have decided to put those aside and do them all at once. On my first major build, the HMS Victory available here at DeAgostini, I initially started making the canons as they arrived with each subscription. I quickly discovered how difficult it is to retain a consistent look from one to the next doing things this way. After about the fourth or fifth one (out of something like 20 or more) I decide to hold off and do them in more of an assembly line fashion. Things worked out much better that way for me. Took it as a lesson learned and it is how decided I would do it going forward.
As for color...great info. I would have gone ahead and just painted them boring old black, but if the pale green is more true to reality I would do that as well. I have never seen Master and Commander, and I bear that shame. I now have it on my watch list for this weekend. Is the ship in that flick the same era and type? You have any luck finding corraborating evidence? I don't always trust what the set makers for movies do as they often change things up slightly for visual improvements.
If you do one, please post on your log. I am keeping a keen eye on your progress and am very curious about the color and the results you get.
COMPLETED:
IN PROGRESS:
tenderfoot
#31 Posted : 01 April 2021 16:13:16
Per the instructions, the next step was to add the top rails. However, after looking at it for a while, and based on some previous experience with the launch aboard the USS Constitution, I thought it would be rather difficult to do this. When you look closely, we are trying to attach a top rail to some very, very, very tiny rib tips. While doing this, the top rail needs a convex bend. Additionally, the ribs need to be manipulated slightly to ensure they all stay in position. Finally, trying to do and this and how was I to keep things in perfect position? No where to effectively clamp, tape, etc. At least, not in a way that would allow fine-tuning.
So I decided to do things a bit out of order and went first to adding the sheer strake. Again, I even decided to change this up a bit partly for looks, but mostly for structural integrity.
It is my understanding and limited experience that the sheer strake is typically wider than the rest of the strakes. The instructions call for a .5mm strake across the board. Because I thought the skiff needed some additional strengthening, plus I wanted to provide some additional surface area for the top rail to adhere, I chose to go with 1mm for the sheer strake. Also, like the decking, I chose to go with a lighter wood for some contrast.
Because of the additional thickness it was necessary to pull out the trusty travel iron and put a bend to the board. Also, because the ribs are soooooo tiny I didn't want to have any real pressure applied, so I took my time and got the bend as accurate as possible.
COMPLETED:
IN PROGRESS:
tenderfoot
#32 Posted : 01 April 2021 16:24:36
Then it came time to adhere the sheer strake to the ribs...this was scary! Any time I touch those itsy bitsy ribs I get nervous...but in a good way...I love building these things.
I started with the port side strake and first glued it to the transom and rearmost three ribs. After this dried I worked my way to the bow. However, once I hit the last 3 ribs I encountered a problem. Although I had bent the strake to fit nicely, it still added some pressure to these three ribs as it made the tight turn toward the stem. All was good for a few moment and then I heard the dreaded crack of wood...I am sure we are all familiar with this sound...it is awful. I swear I awake at night sometimes thinking I hear a board crack...gets to me that much.
The images below show where the strake actually pulled the rib against that thingy at the bow (one day I will figure out what that is called). The torque of the rib twisting also snapped off the tiny bit. The magenta outline shows the original/proper position of the rib and the cyan outline shows where the piece used to be on that thingy at the bow.
Lesson learned...always fair your frame no matte how small. Sadly, the instructions don't call for this and maybe since they use .5mm planks it wouldn't be necessary. But still, I will never make this mistake again. In fact, I went ahead and faired the starboard side just slightly. Couldn't do too much as the ribs are small enough as is. However, what I could do helped tremendously and I avoided the problem on the starboard side. The magenta arrows show the bad, not-faired ribs on the port side and the cyan shows a nice, faired rib on the starboard side. I strongly suggest folks fair these just a bit to avoid the issue I encountered. Again, only needed to do this to the foremost three ribs. And even there, only needed to do it near the top of the ribs where the two strakes will be applied.
Final note on this, I chose not to repair the tiny bit on that thingy at the bow. I don't think it will be visible and because it is soooo small I thought any repair would be more unsightly then the problem I was trying to solve. If anyone visits the house when this is complete, and points that out to me, I will show them the front door Blink
COMPLETED:
IN PROGRESS:
tenderfoot
#33 Posted : 01 April 2021 16:28:44
Here it is with the sheer strake applied to both the port and starboard sides. Again, took my time and applied a couple ribs at a time to allow me to adjust things ever so slightly as I went along. Don't try to adjust too much...these tings are ever so fragile.
At this point I also added all the little bits. Don't yet know what these are called (anyone?) but I highlighted one in magenta so clarify what I am talking about.
I then lightly sanded across the top of the strake and ribs to ensure a smooth surface from bow to stern.
COMPLETED:
IN PROGRESS:
tenderfoot
#34 Posted : 01 April 2021 16:34:47
Finally, the skiff was ready for the top rails. I didn't pre-bend these in any way as the laser cut part was pliable enough to attach without issue. This was straight forward and simple...really happy I added the sheer strakes before I did this step.
However, I was a bit too brutal when clamping things in place and caused two small mars in the port sheer strake (see image below). Thankfully, a bit of water dabbed onto these spots and the wood sprang back into place. Next time I will prebend the rail to prevent this.
With both rails applied, the end product looks really good. Now I think I will set this aside for a while as I continue to contemplate if I want to plank one entire side or not. Still need to add another strake to both sides at a minimum, but this can wait as well.
COMPLETED:
IN PROGRESS:
tenderfoot
#35 Posted : 01 April 2021 16:38:39
Below are a few images showing the skiff from underneath. Just thought these really highlighted the details and also I just like seeing the pattern all those ribs create.
That's going to be it for a couple weeks. Have a big project I need to focus on for work. In the meantime, I will be skulking around the logs...just won't be building anything.
Cheers!
COMPLETED:
IN PROGRESS:
Medric
#36 Posted : 05 April 2021 20:49:26
That little skiff looks tricky. No room for error. Working on this particular model is like going to model builders school. Speaking of colors for the cannons and culverin and anchor, I had another thought. I mentioned the green color of the culverins in Master and Commander. The more I think about it that looks more like tarnished copper than iron. My Dad was in the Navy in WWII and he told me that all they ever did at sea was paint and maintenance, so I imagine those cannons looked pretty spiffy and not tarnished at all. And now a thought about the anchor. There is a seam down the side on the model part. I wonder if that should be sanded off .
Theodore Roosevelt
tenderfoot
#37 Posted : 06 April 2021 14:29:33
I always take the time to clean off the mold seams. To my eye they leap out and I can’t help but notice them, especially when something gets painted...it just highlight the seam even more. Being careful to not accidentally remove intended detail, I strongly encourage you to work the mold seams away. I generally do this with a new blade and scrape along the seam, holding the blade just less than 90 degrees to the piece. You don’t want to cut the seam away, just slowly scrape it. It actually takes almost no pressure or effort, just a bit of time. I will sometimes go back in with a needle file to clean up as needed. Also, especially with pieces that are pre-painted, you will need to go in a touch up where you worked the piece. Or, as I prefer to do to ensure a consistent look, simply paint the entire piece.
COMPLETED:
IN PROGRESS:
#38 Posted : 07 April 2021 18:54:39
I think you are doing a great job. Cool
Keep it coming.
#39 Posted : 08 April 2021 08:50:18
What a great job you are doing, real work of art.Love Love Drool
tenderfoot
#40 Posted : 19 April 2021 18:49:40
I'm back! Finished up a big project for work and was finally able to get back to the real enjoyment in life.
First of all, thank you everyone for your kind comments and words. It is encouraging and makes these logs all the more enjoyable.
COMPLETED:
IN PROGRESS:
19 Pages <1234>»
This page was generated in 0.841 seconds.
