lights for hood kit Options
comic123
#1 Posted : 18 September 2011 11:00:01
Thinking of adding lights to hood instead of r/c as parts should fit in the gaps for motors.
Anyone help with sourcing correct bits or is it not possible?Confused
#2 Posted : 18 September 2011 11:30:14
You would first need to ascertain exactly what you are going to light, and then prodice a hit list of needs, also there is no reason why you could not combine lighting with an R/C build, though unless you sail in the dark, the lighting will be barely visible.
Take a look at the jinks8 diary build for the Yamato which will give you an idea as to what's involved
http://forum.model-space...t.aspx?g=posts&t=67
This page was generated in 0.023 seconds.
