52 Pages «<2223242526>»
1/48 scale U-Boat U230 [Part 3] Options
#461 Posted : 03 April 2021 09:32:44
Truly amazing work Phil.Love Love
Sticky Wickett
#462 Posted : 08 April 2021 20:58:15
A few more details were added to the Engine Room this week.
The attached photo shows an overhead valve handwheel, made from the supplied kit, painted and ready for fitting. The two white metal gauges were sourced from a model railway supplier and were painted in their respective red for port, green for starboard colours.
Sticky Wickett
#463 Posted : 08 April 2021 21:03:57
The first of the attached images shows the dial face for the previous mentioned gauges. This was cropped in Paint 3D, resized in Powerpoint, printed, then covered with a thin, transparent plastic film to simulate glass and finally, as seen in the second image, two were made and fitted. I also added 0.3mm diameter solder to replicate wires.
Sticky Wickett
#464 Posted : 08 April 2021 21:05:39
This photo shows the two gauges fitted above each engine.
Sticky Wickett
#465 Posted : 08 April 2021 21:06:39
This photo shows the valve handwheel fitted in the deck head, between the two engines.
Sticky Wickett
#466 Posted : 08 April 2021 21:07:27
I made a guard to cover the connection between the engine and bulkhead.
Sticky Wickett
#467 Posted : 08 April 2021 21:10:08
The attached images show some paperwork as i wanted to add something to the noticeboard and also to the desk. I sourced a couple of relevant images, again, cropped in Paint 3D, resized in Powerpoint, printed and fixed with double sided tape.
Sticky Wickett
#468 Posted : 08 April 2021 21:17:07
That concludes the update for this week. Next week should see the final part to building the Engine Room. I have to weather and fit the exhaust pipe to the starboard diesel engine, paint, position and fit two crew members and a final oil/rust application to any areas i feel require it.
Thanks for looking in, have a great weekend and happy modelling!BigGrin
Phil W.
goddo
#469 Posted : 09 April 2021 07:27:07
Amazing attention to detail, Phil
Long may your eyesight continue to be good.😀
This is a great build log.
Chris
Kev the Modeller
#470 Posted : 09 April 2021 20:16:08
What more can be said about your fantastic (and very long running) build of this model Phil, other than utterly amazing!
Very well done yet again. Cool ThumpUp
Kev.
Per Ardua Ad Astra
#471 Posted : 09 April 2021 21:28:07
An incredible display of your modelling skills Phil, truly outstanding work throughout.....Love Love Love
#472 Posted : 10 April 2021 10:30:36
Incredible detail, looks amazing Love Drool
#473 Posted : 10 April 2021 15:55:28
Hi some very nice details going into this amazing work and patience, cheers mick.BigGrin
Sticky Wickett
#474 Posted : 15 April 2021 20:47:45
Thank you very much for all the comments guys, much appreciated.BigGrin
So, the final push to complete the Engine Room.
The attached photo shows the exhaust pipe fitted to the starboard diesel engine. I also added a few more rusty patches, which would of occurred due to condensation, using a rust coloured powder. Using a smoke coloured powder i toned down the colours on the diesel engine and then mixed the two powders together and applied that in different areas to the exhaust pipe.
Sticky Wickett
#475 Posted : 15 April 2021 20:49:40
Close up view of the exhaust pipe showing the mixture of smoke and rust powder to great effect i think!BigGrin
Sticky Wickett
#476 Posted : 15 April 2021 20:51:37
The attached photo shows the Chief Stoker [Mechanic], painted up with striped braces and oil covered hands after a bit of on-watch maintenance.LOL
Sticky Wickett
#477 Posted : 15 April 2021 20:52:37
Rear view.
Sticky Wickett
#478 Posted : 15 April 2021 20:53:45
The attached photo shows the on-watch stoker to help out the Chief.
Sticky Wickett
#479 Posted : 15 April 2021 20:55:00
Rear view.
Sticky Wickett
#480 Posted : 15 April 2021 20:58:28
Chief stoker and junior rate stoker on watch in the Engine Room making sure everything is ticking along. I tried to position them so that they tell a story of sorts, with the Chief operating the engines and the junior stoker conducting some valve ops. The Engine Room is now complete!!!!!!!!BigGrin BigGrin LOL LOL Flapper Flapper
This page was generated in 0.365 seconds.
