broken parts need help Options
benny
#1 Posted : 19 September 2011 20:52:46
hi all i have snapped 2 of my studding sail boom irons does anyone know a shop or anywhere i can get some...i dry fitted them and took them out and they just broke
cheers benny
Maldbuild
#2 Posted : 19 September 2011 21:10:50
Not sure where to get them from, I have had the same problem, these pieces are so fragile .
Confused Confused
alantait
#3 Posted : 19 September 2011 21:19:34
sorry benny just had a hunt through my spare stuff but no luck, also checked model dockard and cornwall model boats but nothing listed, only other suggestion is to call scoonie hobbies (kirkcaldy) my local shop tomorrow and see if they can help out. they have done wonders for me in the past.
current builds
#4 Posted : 19 September 2011 21:25:08
if it is any help,this has happened to me in the past,I overcame this by making it up from copper coaxle the centre wire,which was 1.5mm this,I then slightly flattened it,and then wrapped it round a 3mm drill.when painted you cant tell the difference.
benny
#5 Posted : 19 September 2011 21:32:04
thanks all for your help i have been toying with one of the big eyelets,they will do but obviously prefer the original..but will also try all your advice
cheers benny
#6 Posted : 19 September 2011 22:47:25
Good suggestion KarlCool
jeff averre
#7 Posted : 19 September 2011 23:21:14
Seems a common fault, I did the same, I mentioned in an earlier thread that we should probably leave them to the very end when building the yards, to rectify mine I just drilled a hole at right angles to the 'yard' as near as possible to the ends, I don't think it will be too noticeable when finnished. (see photo)
Hope that help's, well probably be doing it again laterCursing
Jeff
IAN
#8 Posted : 20 September 2011 14:39:03
Hi Benny..
I super glued the ring and pin back to gether and stuck it on the end of the mast yard.
hope this helps,
Ian
Ian
Wish list: Bentley Blower
This page was generated in 0.116 seconds.
