52 Pages «<2425262728>»
1/48 scale U-Boat U230 [Part 3] Options
Sticky Wickett
#501 Posted : 30 April 2021 16:34:41
Quick mock up, so i could take further measurements. Unfinished cooker, sink and dividing bulkhead in place.
Sticky Wickett
#502 Posted : 30 April 2021 16:35:50
Sink built up to the correct height. I will also finish this item during the weekend.
Sticky Wickett
#503 Posted : 30 April 2021 16:36:57
Scratch-built provisions lockers.
Sticky Wickett
#504 Posted : 30 April 2021 16:46:14
It was at this point i made a creative decision based on the colour scheme of U995. That is, the Galley has its lower half painted in blue. Whether this was true for other U-boats, i don't know. But i like the colour scheme and will use the term 'artistic license' if i'm ever questioned on it.
So a pencil was clamped to an engineers square and the height set. The dividing bulkhead and provisions lockers were temporarily installed while i ran a pencil line around them, as well as the bulkhead that separates the Galley from the Engine Room.
The bulkhead door was then removed and painted in the same colour scheme, as seen in the attached photo.
Sticky Wickett
#505 Posted : 30 April 2021 16:47:43
Bulkhead door fitted, with the bulkhead painted also.
Sticky Wickett
#506 Posted : 30 April 2021 16:48:28
Provisions lockers painted.
Sticky Wickett
#507 Posted : 30 April 2021 16:50:14
Lockers fitted. I spent a bit of time when masking, so that the blue paint line matched for alignment against the main bulkhead.
Sticky Wickett
#508 Posted : 30 April 2021 16:50:55
Dividing bulkhead painted in the same way.
Sticky Wickett
#509 Posted : 30 April 2021 16:52:01
That concludes this update.
Thanks for looking in, have a great weekend and happy modelling!BigGrin
Phil W.
#510 Posted : 01 May 2021 08:27:36
Very nice work as usual Phil.Love Love Drool
goddo
#511 Posted : 01 May 2021 10:02:22
Great work Phil.
A lovely update on your build dairy.
Chris
Sticky Wickett
#512 Posted : 06 May 2021 18:53:41
So more progress made on scratch-building different items to fit out the Galley.
The attached photo shows the bulkhead door, that divides the Galley from the Junior Rates Accommodation Space, fitted with working hinges. The brass wire is 0.5mm diameter and is not cut to length, merely acting to align the hinges.
Sticky Wickett
#513 Posted : 06 May 2021 18:54:31
Door opened to check hinges.
Sticky Wickett
#514 Posted : 06 May 2021 18:55:33
Looking from another angle.
Sticky Wickett
#515 Posted : 06 May 2021 18:56:23
The opened bulkhead door viewed from the Accommodation Space side.
Sticky Wickett
#516 Posted : 06 May 2021 18:56:56
Bulkhead door painted and handle fitted.
Sticky Wickett
#517 Posted : 06 May 2021 18:57:45
Other side of the bulkhead door showing the handle and lock on the walnut veneer.
Sticky Wickett
#518 Posted : 06 May 2021 18:58:21
Pewter casting of a tap, painted and pin washed.
Sticky Wickett
#519 Posted : 06 May 2021 18:59:33
Tap fitted to bulkhead and door refitted with hinges trimmed to length.
Sticky Wickett
#520 Posted : 06 May 2021 19:00:42
Door opened.
Guest (13)
This page was generated in 0.834 seconds.
