4 Pages <1234>
Hawker Hunter - Large scale ONGOING Options
#21 Posted : 02 May 2021 22:59:57
My eyes are peeled Derek and I'm sure I'll enjoy following your progress.....Cool Cool
admin
#22 Posted : 03 May 2021 04:56:40
RC aircraft are something I’ve assiduously avoided for years. They fall out of the sky, and go crunch! However, I DO have a thing for Armortek kits. They don’t fall, and they will crush anything in the way!
This is going to be beautiful!
goddo
#23 Posted : 03 May 2021 08:17:49
WOW!!!
I’ve just looked at the Amortek web site.
Some of those kits are amazing.
Sadly, the price tags for all of them are way outside my budget.
Maybe if I robbed a bank......?
#24 Posted : 18 May 2021 19:11:11
Hi All, BigGrin BigGrin
Doing some prep work for the start of this build.Blink Blink
I`m using the same build board I used for the "HAWK".
https://forum.model-spac...spx?g=posts&t=33526
It`s a cork notice board that is 47.5" wide x 35.5" high, or in new terms 1.2mtrs x 0.9mtrs. It takes and holds the small map pins very well, so is ideal for the job.Cool
First issue is that the kit is some years old and the plans have been folded for some time and therefore don`t want to lay flat. I have therefore pinned the plan to the board with as much tension as I dare and will let the air get to it for a day and then re-pin it a bit tighter. (See attached pic)
I have purchased the cover for the plans that even at double thickness you can still see the plan and it works out at approx 3gms per sq mtr and only £3 for 12 sq mtrs.
https://forum.model-spac...px?g=posts&t=35082.
As soon as I get the plans as flat as poss, I`ll cover them and get started.
So more soon.BigGrin
goddo
#25 Posted : 18 May 2021 20:04:36
Hi Derek,
Have you considered turning the plan over and ironing it on the back? Not too hot though.
Many years ago I was an "on the board" draughtsman for a structural engineering company so it was before computerised versions were available (I know, that makes me about 200 years old!). Anyway, some of my drawing prints were folded rather rolled and I used the iron method to remove a fair amount of the creases.
Might be worth a try on a dummy piece of paper about the same weight?
#26 Posted : 19 May 2021 21:41:55
goddo wrote:
Hi Derek,
Had thought of that solution, but my ironing skills are zero.LOL LOL
May give it a (careful) try to see if it makes any improvements though.
Thanks for the idea. BigGrin
Mustang
#27 Posted : 19 May 2021 21:45:18
If you place a tea towel or towel over the paper and then iron it you could get them out and not damage the paper this is what I do when ironing my cross stitch fabrics.
To build:-
#28 Posted : 19 May 2021 21:50:53
Thanks BigGrin
Wifey says she won`t iron the plans in case she burns them. Me, I only know how to plug the darn thing in. LOL LOL
Lots of tips, thankyou guys. BigGrin
Mustang
#29 Posted : 20 May 2021 11:56:38
How big is the plan, I have a long postal roll here so if you wanted to posted it to me I would have a look and see if I could iron it out for you then roll it up and post it back.
To build:-
#30 Posted : 20 May 2021 22:02:45
delboy271155 wrote:
Thanks BigGrin
What’s an Iron, have I missed something.BigGrin
#31 Posted : 21 May 2021 08:33:20
Confused Oh come on Mark you know what Iron is , they dig it up and make bridges and things out of it LOL LOL
Martyn
#32 Posted : 21 May 2021 13:33:29
Thanks for the offer of assistance. Cool Cool
Looks like things should be ok as I`ve had the plans pinned out for a couple of days in a warm room and I`ve just re-pinned it to take up the slack as the creases gradually flatten out.
Hope to make a start on this early part of next week.BigGrin
Silent_Running
#33 Posted : 22 May 2021 15:31:39
delboy271155 wrote:
Thanks BigGrin
Hi Derek
Yes! The dry tea towel is exactly how to iron the creases out without burning anything and make sure the steam setting is turned off. Or you could hang it up so it’s loose gripped by two clothes pegs, and use a steam gun or the iron on full steam held at a distance and short bursts of steam. The creases will then drop out. Looking forward to this! BigGrin
#34 Posted : 22 May 2021 16:53:59
Hi there Derek!
Just caught up with your diary! I found this 'how to' video on youtube about removing the creases with the iron method, looks pretty good and the comments section is full of questions and answers too!
Hope it helps and best of luck.
Robin.
https://www.youtube.com/watch?v=fOgWuLhUaRc
#35 Posted : 22 May 2021 18:07:14
WOW Cool Cool Cool
Just shows what you can find out by asking a simple question.Love Love
Thanks for all the suggestions guys. BigGrin BigGrin
I have today removed the right side parts of the front fuselage from their frets and made up a dry fit. Some adjustments may be needed when pinned to the plans, but it all looks close enough for a starting point.
So just the one pic for now, with more to come soon.Blink Blink
#36 Posted : 23 May 2021 09:53:24
Nice start Derek. You’re going to need a lot of room for this one.
#37 Posted : 23 May 2021 19:13:58
Hi Mark, BigGrin
This is a biggun.
I`ve prepped the other side of the front fuselage and trimmed up the pre-formed nose sections in readiness for the big glue-up that`s coming.
Got my second covid jab midday tomorrow so will update asap after that.
#38 Posted : 23 May 2021 21:52:11
Hope you feel better than last time. Got my 2nd on Tuesday afternoon.BigGrin
#39 Posted : 24 May 2021 16:57:59
Hi All, BigGrin
Well second covid jab done and dusted and now got a small update on the Hawker Hunter.
I took an iron (carefully) on a low heat to the plans and I`m pleased to report that they no longer look like a relief map of the Himalayas.Blink Blink
I then put on a double layer of the super thin dust sheet reported on earlier:
https://forum.model-spac...spx?g=posts&t=35082
With the plan protected from glue etc, It was down to laying the first parts and pinning them in place having applied balsa cement on the joining faces. I also placed the first two formers (F1/F2) shown in the pic to hold things stable. These are not glued yet.
Leaving that to set solidly and then I can get some more done and post the next update.Cool
goddo
#40 Posted : 24 May 2021 17:30:44
Hi Derek,
Sounds interesting. Does this sheeting that you mention "stick" like clingfilm or is it non stick?
Chris
4 Pages <1234>
This page was generated in 0.253 seconds.
