52 Pages «<2526272829>»
1/48 scale U-Boat U230 [Part 3] Options
Sticky Wickett
#521 Posted : 06 May 2021 19:02:44
Trim around the bulkhead door opening on the Accommodation Space side. Made from 0.5mm acetal strip, 4 straight lengths were cut and glued, then 4 curved pieces were formed and glued. The trim was then painted in matt black.
Sticky Wickett
#522 Posted : 06 May 2021 19:03:46
Door opened showing the lock and handle.
Sticky Wickett
#523 Posted : 06 May 2021 19:04:50
Cooker finished; painted, varnished and pin-washed. I'm very happy with the way this turned out!BigGrin
Sticky Wickett
#524 Posted : 06 May 2021 19:05:27
Top/front view.
Sticky Wickett
#525 Posted : 06 May 2021 19:06:01
Sink completed with storage locker underneath.
Sticky Wickett
#526 Posted : 06 May 2021 19:07:08
Two white metal saucepans and a kettle, pin washed and added to the cooker.
Sticky Wickett
#527 Posted : 06 May 2021 19:07:42
Looking from above.
Sticky Wickett
#528 Posted : 06 May 2021 19:08:39
Sink full of washing up! Two 3d printed plates and a frying pan!LOL
Sticky Wickett
#529 Posted : 06 May 2021 19:09:47
More scratch-building; this time, an extraction hood to be fitted above the cooker. Made from 0.5mm thick acetal sheet.
Sticky Wickett
#530 Posted : 06 May 2021 19:10:51
Valves and a hand pump for the dividing bulkhead above the sink area.
Sticky Wickett
#531 Posted : 06 May 2021 19:11:20
Painted and fitted to the bulkhead.
Sticky Wickett
#532 Posted : 06 May 2021 19:14:34
All the scratch-built items mentioned in this weeks post. I can't really fit them yet, as i still have to make the aft escape tower. If i were to fit these items first, then i would be left with no room to make the escape tower, so it's all a bit of a jigsaw. Once the tower is made, i can then start to fit the Galley out, working towards myself as i go.
Sticky Wickett
#533 Posted : 06 May 2021 19:15:35
That concludes this weeks update.
Thanks for looking in and your comments, have a great weekend and happy modelling!BigGrin
Phil W.
Sticky Wickett
#534 Posted : 13 May 2021 17:14:21
Continuing on from last week, i have been gradually fitting out the Galley.
First job this week was to scratch-build the aft-escape tower.
The attached photo shows it prior to painting. Using a compass cutter and 0.5mm thick acetal sheet, i could make several discs of various diameters and glue them together to form the profile. The locking handles were formed from brass strip, bent to shape and the hand-wheel is an after market part.
Sticky Wickett
#535 Posted : 13 May 2021 17:15:10
Aft-escape tower painted.
Sticky Wickett
#536 Posted : 13 May 2021 17:16:47
Aft-escape tower fitted to the deck-head of the Galley.
Sticky Wickett
#537 Posted : 13 May 2021 17:18:30
The attached photo shows the cooker and extraction hood fitted and a very small utensils box equipped with two ladles, situated by the bulkhead door, also fitted.
Sticky Wickett
#538 Posted : 13 May 2021 17:19:07
The attached photo shows the dividing bulkhead and sink fitted.
Sticky Wickett
#539 Posted : 13 May 2021 17:20:12
This photo shows the Galley partly fitted with tread-plate.
Sticky Wickett
#540 Posted : 13 May 2021 17:21:17
The cook, in his chefs whites.
Guest (30)
This page was generated in 0.430 seconds.
