Another view of the cook. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The cook, rotated round for another view. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The final photo of the cook before he takes up his position. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The cook, keeping busy in the Galley. I'm very happy with the way he's positioned and looks to be engaged in 'pot management'!  Funny to think he came from a Revell Luftwaffe set as Ground Crew!  . Splash a bit of white on his tunic and viola, a U-boat master chef! Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
That concludes this weeks post. Thanks for looking in, have a great weekend and happy modelling! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Fantastic level of detail, Phil. I am totally gob smacked. You'll be telling me next there are hand made peas in the saucepan? Chris
I`m lost for words............. (10 mins later  ) How wide is that galley between the two bulkheads as it looks so realistic for such a small space. I take it that you never messed the chef about on a sub as there`s nowhere to run to when he has a cleaver in his hand. Looking forward to the next update. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Lovely work Phil. The level of detail is stunning, just stunning. Wonder if Gordon Ramsey could work in such confined spaces, probably not. Mark Regards Markwarren (Mark) Admin
Good morning from 'The Dockyard'. Thankyou for all the comments and i'm sure you'll have a chuckle at the updates i have for you this week. So i started to build the WC with a hinged door, so you could still see the cook at work when it was opened. The attached photo shows the basic shape made from 0.5mm thick acetal, with door cut-out and corresponding door. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Door in place, hinge pins not fitted at this point. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Looking from the 'business' end  , showing the 3d printed toilet in place to give an idea of it's position. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Hinge pins made from 0.5mm diameter brass rod, fitted. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Door opened. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I then made a toilet roll holder from a small length [3mm] of wooden tooth pick, sanded to a smaller diameter [1mm], with a 0.5mm diameter hole drilled through its centre. I fitted a piece of bent brass wire through the hole to fix to the WC wall. I cut out a small piece of toilet paper, wrapped and glued it around the holder and sprayed it with a bit of matt acrylic varnish to hold it's shape and prevent it from falling apart over time. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The next job was to paint the toilet and add the flushing valve. The toilets were made from stainless steel on submarines as opposed to porcelain and were flushed with pressurised sea water and the waste discharged into the sewage tank below. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Looking from another angle. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Next to the WC was the vegetable stores. So i bought a packet of after market sacks, made of plaster, which also came with a little packet of loose potatoes. Brilliant! I glued a few of the smaller potatoes into the top of the open sack i had earmarked to use. Although i did feel that the sack and the potatoes could do with a bit more dirt. So rather than mix up a brownish wash, i used the real thing. Yes, i went into the garden, got a tablespoonful of soil, placed it on a saucer, dried it out in the microwave and with a damp brush, applied it over the sack and potatoes. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Looking from above. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
A quick mock-up showing the WC, toilet and sack of potatoes. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Guest (12)
