Joined: 11/02/2016 Posts: 36 Points: 88 Location: Edinburgh
Greetings and felicitations,
Do any of you good folk know, or even hazzard a guess... as to the supposed manufacturer of the brake calipers on the kit? Reason I ask is that I, like many of you, would like to add additional detailing, such as brake lines to the model and knowing the maker of caliper takes the guess-work out of where to put said brake lines. Calipers on the kit don't seem to match any type I've found on google...
Brake calipers are manufactured by willwood For better quality images take a look at either Shelby American black gt40 limited edition or Superformance gulf coloured gt40 Hope this helps
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,868 Points: 17,756 Location: ipswich
Car 6 apparently used Girling CR and BR calipers. A friend of mine owns an original GT40 and is a mine of information. Hope it helps.
Many thanks, Roy You may be 100% correct and I do sincerely appreciate that But getting detailed information is such a mission I only have two websites Superformance or Shelby American To get detailed information from Once again many thanks
Thanks folks. Kit's calipers bear no resemblance to either Wilwood or Girling calipers. Think I'm gonna plump for the Girling CR's. I've seen loads of pictures of gt40's with solid discs and the CR's fitted, (just not sure if slotted discs had 'em). I'm doing the Agora Cobra as well and it's got CR's fitted. Many thanks for your advice, guys.
