Brake Calipers?? Options
mr_frog
#1 Posted : 16 May 2021 15:36:27
Rank: Amateur Level 1
Greetings and felicitations,
Do any of you good folk know, or even hazzard a guess...
as to the supposed manufacturer of the brake calipers on the kit?
Reason I ask is that I, like many of you, would like to add additional detailing, such as brake lines to the model and knowing the maker of caliper takes the guess-work out of where to put said brake lines.
Calipers on the kit don't seem to match any type I've found on google...
JOHN-GT40
#2 Posted : 16 May 2021 22:22:18
Brake calipers are manufactured by willwood
For better quality images take a look at either
Shelby American black gt40 limited edition
or
Superformance gulf coloured gt40
Hope this helps
#3 Posted : 16 May 2021 22:33:17
Car 6 apparently used Girling CR and BR calipers.
A friend of mine owns an original GT40 and is a mine of information.
Hope it helps.BigGrin
JOHN-GT40
#4 Posted : 16 May 2021 23:36:32
Many thanks, Roy
You may be 100% correct and I do sincerely appreciate that
But getting detailed information is such a mission
I only have two websites
Superformance or Shelby American
To get detailed information from
Once again many thanks
mr_frog
#5 Posted : 17 May 2021 07:53:41
Thanks folks.
Kit's calipers bear no resemblance to either Wilwood or Girling calipers.
Think I'm gonna plump for the Girling CR's. I've seen loads of pictures of gt40's with solid discs and the CR's fitted, (just not sure if slotted discs had 'em).
I'm doing the Agora Cobra as well and it's got CR's fitted.
Many thanks for your advice, guys.
This page was generated in 0.031 seconds.
