52 Pages «<2728293031>»
1/48 scale U-Boat U230 [Part 3] Options
Sticky Wickett
#561 Posted : 20 May 2021 07:29:44
Before i could fit these items i had to make another food locker, which will be located next to the door on the dividing bulkhead. I could only get the dimensions for it when the WC was temporarily fitted with door open, which is why i didn't make it before.
Sticky Wickett
#562 Posted : 20 May 2021 07:30:19
Painted, varnished and pin-washed.
Sticky Wickett
#563 Posted : 20 May 2021 07:31:27
Two sections of treadplate, painted and ready for fitting to cover the rest of the Galley deck.
Sticky Wickett
#564 Posted : 20 May 2021 07:32:04
WC fitted, door opened.
Sticky Wickett
#565 Posted : 20 May 2021 07:34:45
Toilet and the sack of potatoes fitted.
Sticky Wickett
#566 Posted : 20 May 2021 07:38:10
That concludes this weeks update and the Galley is now completed. I've loved adding all the small, human touches to this section of the u-boat. It makes a nice change from building pumps, pipes and valves!LOL
Thanks for looking in, have a great weekend and happy modelling!BigGrin
Phil W.
goddo
#567 Posted : 20 May 2021 09:28:10
Lost for words to describe this build.
Brilliant.
Chris
#568 Posted : 20 May 2021 21:57:45
It is nice to see you really getting bogged down with this update.Love Love SorryBigGrin
Very nice work.Love Love
#569 Posted : 20 May 2021 22:52:30
Stunning work.... It's the little personal touches you do that makes this build into a true work of art.... Love it....Love Love Love
Sticky Wickett
#570 Posted : 27 May 2021 20:57:22
So this week i began to fit out the Junior Rates Accomodation Space.
The attached photo shows the lower bunk space, with the 'bunk shelves' painted in sky grey. The bottom edge of the lower bunks has been lined with genuine walnut veneer. It makes so much difference working with 'real world' materials rather than trying to paint plastic to look like wood.
Sticky Wickett
#571 Posted : 27 May 2021 21:02:18
The next job was to make 6 mattresses. For this i used 0.5mm thick acetal sheet, cut to size to fit the lower bunk space. As before i used real materials to make the mattress covers, in this case, dark brown cotton tape. I cut out 6 sections of the cotton tape, applied double sided tape to each piece and then wrapped them around the acetal profiles. The double sided tape worked a treat.BigGrin
Sticky Wickett
#572 Posted : 27 May 2021 21:06:16
This photo shows a quick 'mock-up' with 2 of the mattresses in place and a scrap piece of walnut veneer to show the final finish.
Sticky Wickett
#573 Posted : 27 May 2021 21:08:31
I then proceeded to make 3 pillows. Using a small piece of thick card, taken from the cat's food cartonLOL. I cut it to shape and applied a piece of double-sided tape to one side.
Sticky Wickett
#574 Posted : 27 May 2021 21:09:49
Using a thin strip of kitchen towel, cut to the same width as the cardboard, i folded it over several times and then pressed it onto the double-sided tape.
Sticky Wickett
#575 Posted : 27 May 2021 21:12:12
To make the pillow cases, i used small pieces of cotton sheet, wrapped around the kitchen towel and fixed with double-sided tape. BigGrin
Sticky Wickett
#576 Posted : 27 May 2021 21:16:07
One of the crew figures i bought a while ago, made of white metal, was in the sleeping position. I carefully cut away the pillow, painted the figure and the icing on the cake was when i added thin cotton jersey, in grey and glued it over his blanket. It has made so much difference, rather than trying to paint a blanket.BigGrin
Sticky Wickett
#577 Posted : 27 May 2021 21:18:17
The attached photo shows a quick 'mock-up' showing the sleeping crew member. This picture shows, with a little bit of thought, how 'real materials' can bring a model to life.
goddo
#578 Posted : 27 May 2021 21:19:20
Great imagination and skill there, Phil.
The pillow and blanket are brilliant.
Keep it coming.
Chris
Sticky Wickett
#579 Posted : 27 May 2021 21:20:53
I then turned my attention back to the bunk space and fitted more walnut veneer.
Sticky Wickett
#580 Posted : 27 May 2021 21:21:33
The same part, test fitted into the U-boat.
Guest (15)
This page was generated in 1.032 seconds.
