 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,868 Points: 17,756 Location: ipswich
In pack 11, step 43, the instructions shows the brake cooling vent intakes mounted on the opposite sides to how they should fit. They also refer to them as brake fluid brackets which clearly they are not. Attached below is a picture of the correct installation. roymattblack attached the following image(s):
The build guide has been updated, thanks to Roy and Andreas’ catch.
Joined: 28/01/2016 Posts: 46 Points: 131 Location: Pennsylvania, U.S.
I'm working on Pack 11 right now and I thought that was an error! Glad I checked here to reinforce that I'm not going crazy!
