52 Pages «<2829303132>»
1/48 scale U-Boat U230 [Part 3] Options
Sticky Wickett
#581 Posted : 27 May 2021 21:24:01
goddo wrote:
Great imagination and skill there, Phil.
The pillow and blanket are brilliant.
Keep it coming.
Chris
Thank you Chris!BigGrin Glad you're enjoying the build!
Phil W.
Sticky Wickett
#582 Posted : 27 May 2021 21:25:24
The attached photo shows the lower part of the top lockers, or rather, the top of the bunk space!Confused LOL.
Sticky Wickett
#583 Posted : 27 May 2021 21:26:48
That concludes this weeks update.
Thanks for looking in, have a great weekend and happy modelling!BigGrin
Phil W.
Sticky Wickett
#584 Posted : 03 June 2021 20:39:01
More progress made on fitting out the Junior Rates Accommodation space. Not many photos this week, but plenty of work involved to get to this stage.
So the attached photo shows a scratch-built bunk, made from acetal sheet and square section, painted sky grey and fitted with a mattress, pillow and sleeping, off-watch, crew member.
Sticky Wickett
#585 Posted : 03 June 2021 20:39:34
Looking from another angle.
Sticky Wickett
#586 Posted : 03 June 2021 20:41:12
Remaining mattresses fitted, with one folded down, as we used to do, to make a back rest and a turned back sleeping bag. All items were fixed using double-sided tape, which worked a treat!BigGrin
Sticky Wickett
#587 Posted : 03 June 2021 20:41:43
Looking from a different angle.
Sticky Wickett
#588 Posted : 03 June 2021 20:42:31
Bunk space fitted.
Sticky Wickett
#589 Posted : 03 June 2021 20:46:33
That concludes this update. I have also partially painted 5 more crew members, fitted a hinge to the hatch, made up a few junction boxes, but none of these were finished, so will update in time for next weeks post.
Thanks for looking, have a great weekend and happy modelling!
Phil W.
#590 Posted : 04 June 2021 09:56:27
This is a great build Phil, watching all the time.
Trev
goddo
#591 Posted : 04 June 2021 11:57:29
Hi Phil,
Excellent stuff. Keep it coming. BigGrin BigGrin
Chris
#592 Posted : 04 June 2021 13:56:00
Amazing work Phil.Love Love Drool You must lay in bed at night thinking of what to do next.LOL
Sticky Wickett
#593 Posted : 10 June 2021 20:22:20
Thank you Mark! Yes, i do spend a bit of time thinking about it all whilst lay in bed before i drop off.LOL Recently, with the longer days, i have occasionally got up at 5am to crack a couple of hours in before i go to work! Crazy! But i feel the end could be in sight by the end of year!!!BigGrin
Phil W.
Sticky Wickett
#594 Posted : 10 June 2021 20:23:21
More progress on fitting out the Junior Rates Accommodation space.
First up, an isolation valve.
Sticky Wickett
#595 Posted : 10 June 2021 20:24:04
Isolation valve fitted.
Sticky Wickett
#596 Posted : 10 June 2021 20:25:06
I then made various junction boxes.
Sticky Wickett
#597 Posted : 10 June 2021 20:25:51
Some of the junction boxes fitted together before installing on the bulkhead.
Sticky Wickett
#598 Posted : 10 June 2021 20:27:11
All junction boxes fitted to the bulkhead, along with the repositioned bulkhead door, sporting it's hinge, which i forgot to add last time.
Sticky Wickett
#599 Posted : 10 June 2021 20:27:38
Isolation valve and pipe.
Sticky Wickett
#600 Posted : 10 June 2021 20:29:10
Isolation valve fitted with pipe, along with another pipe and 2 red valve handwheels, connecting to the extraction ducting in the deck head.
Guest (11)
This page was generated in 0.425 seconds.
