Joe Bergman Pack 12 Welcome Back To The Build Options
bojazz
#1 Posted : 29 May 2021 20:26:46
Rank: Beginner Level 3
Hello all and this is next time.
Welcome to the Builds for Pack 12
Stage 46 Left Front Suspension
Before assembling this to the sub-frame. Part 46C was painted in flat black to match the sub-frame and parts 46A and 46C has Tamiya Black Panel liner in the recess. When all was dry, it was installed on the sub-frame
I have installed the tire on the rim for the right wheel before mounting it to the struts without any damage to the mounted suspension parts and shock absorber in Stage 45 Pack 11 and Stage 47 Pack 12.
Before I installed this assembly on the suspension and shock absorber. I added a Tamiya Dark Brown Panel wash in the recesses of the orange part of the wheel hub.
I screwed in the entire right wheel assembly (with tire mounted). It worked like a charm with no damage issues.
I hope this part was enjoyable and looking forward to seeing you on Pack 13. This is going to be a nice build.
bojazz attached the following image(s):
This page was generated in 0.134 seconds.
