I started back in 2010,did some progress but I work more than fulltime and had to move a couple of times. Like a wood builder, the timber had time to rest.  Now I continued the work, so that's where I am.
Hi Agionte, Welcome to the forum. Good to have another Victory build diary. There are loads of members on here who are a huge help with tips and guidance should you get a bit stuck. Look forward to seeing you progress. Chris
Welcome aboard, great to have you with us.... Regards Alan
Joined: 21/08/2010 Posts: 35 Points: 110 Location: Now in Berlin, Germany
HI, Admin did some magic and I have now access to my "old" Skipper profile. Hurray, so what I will do - Skipper is for my HMS Victory build and my other profile is for the continuation of the VASA model. I think this is more than appropriate. I will be more active on the forum too - in the past I was more a "passive reader" to learn a lot from all the tipps and tricks here. It's time to pass some on what I have learned so far.....rule 1: be patient! It's a fantastic and rewarding hobby but first thing was to learn: be patient and look out for the detail.
Joined: 25/03/2011 Posts: 1,027 Points: 3,075 Location: Lincolnshire
Welcome back Skipper, a warm welcome to you from your shipmates Regards Glenn
