Joined: 06/09/2011 Posts: 115 Points: 354 Location: Bristol
Hi All, It`s been quite a while since I posted anything on here but have been busy modelling away. Anyway having finished another conversion of a card model to wood/plastic/metal/card of a 1:200 model of the USS North Carolina I decided to build an aircraft carrier next and settled on the big `E` the USS Enterprise CV6. This will be another conversion from a card model. Model Dimensions Length - 1260mm Beam - 180mm Height - 270mm Ken
Completed Models IJN Yamato, Hachette Titanic, Del Prado Victory, Tamiya 1/16 RC Pershing Tank, HMS Naiad, HMS Prince of Wales, Admiral Hipper, Tirpitz, USS North Carolina [Current Build USS Enterprise CV6
Hi Folks. Photocopied all hull parts and transferred to timber. Cut out and glued together. Following the same construction as for card, a strong and rigid hull is achieved. Reduced outline of all frames by 1mm to allow for the first layer of planking Ken
Hi Ken,
If you can, size your pictures to 600x480 pixels, and they will display automatically. This increases views of your pictures.
If you are lacking the software, I’d be happy to resize them for you.
Best,
Hi Mark, Thank you for the advice and offer of help. Managed to find a free photo resizing site on the internet and will be giving it a go. Ken
Hi All, Timber decks fitted and card decks loose fitted to check for alignment and sizing. Positioned some of the card structure which will be covered using plastic card and sections. Ken
Hi Ken I get this message when trying to see your pics
Please do not link directly to this resource. You must have a session in the forum. ?????
Hi budgie, Not sure what that means, perhaps admin could help? Ken
Hi Ken I just downloaded the last pic you posted. The picture size is perfect but the file format needs to be .jpg and not .jpeg then your pics will appear and not be downloads. Hope this helps. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Delboy Once again thanks for the info. It seems that the image resizer I used converted from jpg to jpeg when converting several files but OK one at a time, so will do this in future. Thanks Ken
Ken wrote:Hi Delboy Once again thanks for the info. It seems that the image resizer I used converted from jpg to jpeg when converting several files but OK one at a time, so will do this in future.
Thanks You are most welcome. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi All Hopefully I`ve got the pictures right. Started the first layer of planking. The model of Enterprise (1944) I`m building had torpedo bulges added and this makes the first layer slightly more involved. Started planking where there are definite lines between bulge and hull as seen on the frames. I also used the card sections as a reference on the hull where solid timber will be shaped. the bow and stern sections will be filled with solid timber when the second layer is completed. Ken attached the following image(s): Ken
HI Ken, Happy to say the pics are bang on now. Well done for your persistence. Keep the updates coming, I`m watching for sure. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Delboy Happy that it has worked. Will keep posting more as model progresses. Ken
With such a project - you must be crazy!!
But in a good way!! Greetings, Walter
I am Crazy but in a good way lol. Ken
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,361 Points: 22,390 Location: Northamptonshire, England
That is coming on very nicely, love what you are doing. Mark Regards Markwarren (Mark) Admin
Hi All, Thanks for the comments. First layer complete and sanded smooth ready for layer 2. Ken attached the following image(s): Ken
Hi Ken nice smooth hull Looks like the frames are quite thin for pinning the hull planks to but looks like this has not given you any issues
Hi Budgie, The frames are 1.5mm lime and the 1st layer of planking is only 1mm thick and vary from 5mm to 2mm wide and using dressmaker pins and planks moistened for the ends and sharp bends they can be carefully pinned without too much splitting. Ken
Hi All, 2nd layer of planking completed and sanded. Bow and stern also filled and sanded smooth ready for prepping for paint. Ken attached the following image(s): Ken
Guest (9)
