Stage 53-1; where do the wires go? Options
Eagle
#1 Posted : 13 July 2021 14:53:57
Red Medal: Red Medal
The site download identifies the two front06 and 07 wires protruding in the cowl post areas, but what of the 08 and 09 cables, do they tuck underneath or hang loose out the side ?
Confused
#2 Posted : 13 July 2021 15:24:10
I did a bit of head-scratching here too and after magnifying one of the instruction picture I found where they go.
They route under the floor to the opposite side of the car and exit under the battery box.
Roy.
semaj
#3 Posted : 31 July 2021 21:24:54
I am also struggling with this, same with the front wires. Currently I have them routed as the images 8n the instructions show, but this can't be right surely as they would get trapped when the bodywork is fitted and they just don't look right loose around the wheel arches
Building:
Complete:
#4 Posted : 01 August 2021 09:16:11
I think the actual routing will become much clearer when the body starts to be added and the lights etc are connected.
semaj
#5 Posted : 15 August 2021 12:06:49
The thing is, there does seem to be some obvious locations on the interior section where the wires are supposed to come through at the front and rear but the instructions show the wires coming out in the wheel arches. As you say, it could become clearer when the body is fitted in the future but due to how the rear section hinges from the very back, atm I fail to see how the wires are going to be hidden coming from where they are currently and routing to the tail lights. One wire doesn't even seem long enough unless it routes directly over the engine
Building:
Complete:
#6 Posted : 15 August 2021 15:23:58
I agree. IF those two wires somehow go to the rear lights, then it's possible that later on, the shorter of the two might have to go back under the floor to come out on the correct side.
However, as I mentioned previously we'll find out in due course.
mortyjeff
#7 Posted : 16 August 2021 18:03:11
Rank: Beginner Level 3
Not to worry, if the lights are like the ones on the Lamborghini, they will come with their own pig-tail and connector, plenty of wire (if not excess).
All will be revealed in due time.
Cool
mortyjeff attached the following image(s):
This page was generated in 0.043 seconds.
