Brass cannon stops Options
Korik
#1 Posted : 27 July 2021 12:58:39
Rank: Newbie
Hi All,
Just about to start the build, and the only thing that is worrying me is the bending of the brass cannon stops. if not done right, I can see them looking a right mess!
Does anyone have any advice for doing this? I've built a few wooden ships before but never worked in brass in this way.
#2 Posted : 28 July 2021 22:25:41
I tend to heat the brass strip first over a candle. Once heated, bend the strip over a metal rod of the correct thickness, such as a screwdriver. Applying a little heat makes the brass more malleable but would suggest you carry out a test on a brass offcut first....
This page was generated in 0.323 seconds.
