52 Pages «<3233343536>»
1/48 scale U-Boat U230 [Part 3] Options
Sticky Wickett
#661 Posted : 29 July 2021 20:20:45
Both items i've described were then fitted to the their hull section.
Sticky Wickett
#662 Posted : 29 July 2021 20:22:05
Full length view of this hull section showing all the equipment i've mentioned in the last few posts.
Sticky Wickett
#663 Posted : 29 July 2021 20:22:27
From above.
Sticky Wickett
#664 Posted : 29 July 2021 20:23:31
That concludes this update, more to follow next week.
Thanks for looking in, have a great weekend and happy modelling.BigGrin
Phil W.
goddo
#665 Posted : 30 July 2021 10:26:27
Great stuff Phil.
Keep it coming.
Chris
Kev the Modeller
#666 Posted : 30 July 2021 13:47:08
Some fantastic scratchbuilding skills on show here Phil, as always. I am constantly amazed at how much extra detail you are able to add to each section of this build. You must have some very comprehensive reference material?!
This will certainly be something to behold when finished!! DroolDroolThumpUp
Kev
Per Ardua Ad Astra
#667 Posted : 30 July 2021 21:42:22
Another excellent update philBigGrin glad you had a good holidayCool
Regards PhilCool
#668 Posted : 31 July 2021 06:35:01
Very nice Phil, as Kev said you must have some great reference material.
#669 Posted : 31 July 2021 09:30:22
Excellent scratch Phil great stuff.
Trev
#670 Posted : 05 August 2021 15:52:13
I never cease to be amazed at what you manage to produce. Well Done.
Cool Love Cool Love Cool
Sticky Wickett
#671 Posted : 05 August 2021 21:36:07
So lots more progress this week in fitting out the Control Room.
The attached photo shows the trim pump, enhanced with many scratch-built parts to bring it to life.
The trim pump is used to move water from one internal tank to another throughout the submarine to keep it level when dived.
Sticky Wickett
#672 Posted : 05 August 2021 21:36:49
Looking from another angle.
Sticky Wickett
#673 Posted : 05 August 2021 21:37:20
Trim pump fitted to the hull section.
Sticky Wickett
#674 Posted : 05 August 2021 21:44:12
I then started on the ballast pump, again, adding many scratch-built parts. This pump will be fitted to the aft bulkhead once i have the deck plate fitted next week.
The ballast pump is used to pump water out of the submarine or bring water in. For example, if a torpedo is fired, the weight of the torpedo has to be compensated for and this is where the ballast would be used to pump sea water into the submarine into the torpedo compensating tank. When alongside, it would be used to pump out the sewage tanks and discharge to a tank on the jetty.
Sticky Wickett
#675 Posted : 05 August 2021 21:44:42
Completed ballast pump.
Sticky Wickett
#676 Posted : 05 August 2021 21:48:30
Now it was time to fit the forward and aft bulkheads, deck head and lower hull section into the Control Room and start to bring it to life!BigGrin Lots of fiddly work and nothing would go together straight away as a valve handwheel would catch or the pipes would be in the way, but eventually i got all the parts located and glued.
The attached photo is looking aft.
Sticky Wickett
#677 Posted : 05 August 2021 21:48:56
Looking forward.
Sticky Wickett
#678 Posted : 05 August 2021 21:50:09
Side view.
Sticky Wickett
#679 Posted : 05 August 2021 21:51:16
That concludes this weeks update, more to follow next week.
Phil W.
goddo
#680 Posted : 05 August 2021 22:06:46
Phil, this just keeps getting better with every post.
Brilliant detail.
Chris
This page was generated in 1.243 seconds.
