Just checking when the issue 20 pdf file will be online to download as the next pack will be delivered soon. Thanks
I'm waiting as well. My issue #20 is in the post as we speak. Be a tad taxing to build it with no instructions. There are only 4 issues left, those are not posted either.
The build guides are, and have been running behind. You won’t see all of them posted at one time until the build is complete.
Best,
Joined: 25/02/2018 Posts: 8 Points: 14 Location: Port St Lucie, FL
If it helps, the Italian site has Pack 20 up. You just need to know Italian! https://www.model-space....odellino-del-mig-29.html
[quote=Sooks569]If it helps, the Italian site has Pack 20 up. You just need to know Italian! https://www.model-space....dellino-del-mig-29.html[/quote] One of the really good things about the build guides is that the pictorial directions are very well done. Being able to speak Italian isn’t really necessary. Thanks for the heads up! Stay well Mark
