52 Pages «<3435363738>»
1/48 scale U-Boat U230 [Part 3] Options
Sticky Wickett
#701 Posted : 19 August 2021 20:14:16
Thanks for all the comments gents, much appreciated and glad you like the updates.
So, more work on the Control Room. This week was painting the crew and a few other bits of equipment.
The attached photo shows the Commandant, who will be manning the sky periscope, hence his pose with the periscope body in the same picture. I drilled out his hands slightly so that he actually holds on to the handles.
Sticky Wickett
#702 Posted : 19 August 2021 20:15:20
In position.
Sticky Wickett
#703 Posted : 19 August 2021 20:16:13
Close up.
Sticky Wickett
#704 Posted : 19 August 2021 20:18:23
The next step was to make up the watch keepers bench. It was just an l-shaped bit of part-works plastic and the instructions said to paint the top beige. Beige! No thanks!Flapper Flapper So i got to work with the leatherette.LOL
Sticky Wickett
#705 Posted : 19 August 2021 20:18:54
Watch keepers bench fitted.
Sticky Wickett
#706 Posted : 19 August 2021 20:21:01
I have also been busy painting the rest of the crew that will inhabit the Control Room. They're not quite finished and i will photo them individually when they're done and also when they're in position.
Sticky Wickett
#707 Posted : 19 August 2021 20:25:17
I also started on the Office Of the Watch station. A place to write up notes whilst on watch. Not quite finished, mostly part-works with a few touches by me including the real mahogany edging the desk.
Sticky Wickett
#708 Posted : 19 August 2021 20:28:47
That concludes this update. Big week next week, as i hope to get the Control Room finished and close this part of the build out. Then it's onto the Officers quarters, radar shack and sonar room!BigGrin
Thanks for looking in, have a great weekend and happy modelling!BigGrin
Phil W.
#709 Posted : 20 August 2021 09:35:14
Amazing work. Those figures really bring it to life.Love Love Drool
Kev the Modeller
#710 Posted : 21 August 2021 16:33:16
More fabulous work on this amazing model Phil. If they ever do a re-make of the old 'Das Boot' series they'll be calling you up as a consultant for interior detail on the internal set for the U-boat!!
Love the stance of the Commandant and the way that he is hanging on to the periscope. Very relaxed and natural looking and well painted too.
Top work as usual Phil keep it coming, as I know you will.
Kev
Per Ardua Ad Astra
Sticky Wickett
#711 Posted : 26 August 2021 19:25:41
Thankyou for all the comments gents, much appreciated!BigGrin
So this week i wanted to complete the Control Room, however, there was still too much detail to add and so that will be next week. In the interim, i have been flitting all over the place, making up details for the outer hull section, which were taking longer than envisaged and so i came back to adding more crew.
The attached photo shows the hull section for the Control Room painted. Weathering to follow next week.
Sticky Wickett
#712 Posted : 26 August 2021 19:29:40
The inside of this hull section. The blue gas bottles are part-works supplied, with scratch-built ends. The original locations for these on the hull section were incorrect, so i filed these off and then repositioned the gas bottles as you see here. I then spent quite a bit of time ensuring this hull section would fit neatly into the Control Room, by filing off edges here and there.
Sticky Wickett
#713 Posted : 26 August 2021 19:37:08
The next details i scratch-built to add to this hull section were the hydroplanes controls. The OMC [One Man Control] on modern submarines can be controlled by one person and operates the fore-planes, after-planes and rudder. The OMC, or helm, looks like a steering wheel type affair. On U-boats, the fore-planes were controlled separately to the after-planes while the rudder was controlled from the Aft Torpedo Compartment.
The attached photo shows the fore and aft hydroplanes controls.
Sticky Wickett
#714 Posted : 26 August 2021 19:37:49
Another view of the fore and after hydroplanes controls.
Sticky Wickett
#715 Posted : 26 August 2021 19:38:27
Painted and fitted to the hull section, including a 4th gas bottle, gas pipes and spots of rust where the bottles were 'dinked' during loading.
Sticky Wickett
#716 Posted : 26 August 2021 19:46:42
This hulls section was then test fitted, not for the first time, to show you how it will look when completed.
Sticky Wickett
#717 Posted : 26 August 2021 19:47:07
From another angle.
Sticky Wickett
#718 Posted : 26 August 2021 19:52:07
Above the 4th gas bottle in the previous photo, on U995, there is a huge bank of valves and valve handwheels; i would say about 30 of them, all the way up the hull to the deck-head. I decided to model a small number of these to give an impression of the complexity. I didn't finish them as they took ages to get to this stage, see attached photo, but will continue with these during the weekend.
Sticky Wickett
#719 Posted : 26 August 2021 19:57:40
It was at this point that i decided to concentrate on what i could finish this week and that was fitting out the Control Room with more crew and the OOW's desk, both of which i previewed last week.
The attached photo shows the Navigator.
Sticky Wickett
#720 Posted : 26 August 2021 19:59:19
Access ladder for the Bridge, painted and ready for fitting.
Guest (11)
This page was generated in 4.757 seconds.
