6 Pages «<23456>
1/72 Stalingrad Tractor factory Assault and Battle for the Reichstag Options
#61 Posted : 19 August 2021 20:19:49
Markwarren wrote:
Very nice Phil, just gets better every time. The Vallejo water effect is great, just watch out for bubbles when applying from the bottle.
Great work.
Thanks MarkBigGrin yes i have just applied it in small amountsBigGrin thanks for the heads up thoughCool
Regards philCool
Kev the Modeller
#62 Posted : 21 August 2021 16:15:59
I think this is one of your best builds Phil, great imagination that has been brilliantly executed to bring about a fantastic diorama, with a story that is easy to read just by looking at it!
Fabulous work, well done! Cool ThumpUp
Kev
Per Ardua Ad Astra
#63 Posted : 21 August 2021 20:47:03
Kev
Thankyou KevBlushing really appreciate your comments mate i try my bestBigGrin
Regards PhilCool
#64 Posted : 21 August 2021 20:48:12
Panzer 1V built along with Pak 40 and 251 half trackBigGrin
#65 Posted : 21 August 2021 20:51:09
Moved the base onto some scraps off wood i hadBigGrin added bomb crater and some debris BigGrin before i added the base coat of texture of plaster of parisCool the blue parts are from the base of the old aifix waterloo base i hadCool
#66 Posted : 21 August 2021 20:55:22
the texture for the landscape around the plant was added plaster of paris then painted dark brownBigGrin
#67 Posted : 21 August 2021 20:57:35
I then made up some bits and pieces what will be used around the plantCool
#68 Posted : 21 August 2021 20:58:44
Box`s made from scrap woodBigGrin
#69 Posted : 21 August 2021 20:59:36
More debris added to the stranded T-34Cool more water affect added to bomb craterBigGrin
#70 Posted : 21 August 2021 21:01:39
Started the clean up and primed some of the German troopsCool
#71 Posted : 21 August 2021 21:35:34
This is all looking brilliant Phil, like the small scratch boxes, looking forward to seeing the German troops painted bet you have a load to do.
Trev
#72 Posted : 24 August 2021 11:24:04
Trev
Thanks trev BigGrin yes plenty of troops Blink my take a whileLOL
Regards PhilCool
#73 Posted : 25 August 2021 17:46:01
Hi looks more realistic the more I look in ,cheers mick. BigGrin
#74 Posted : 25 August 2021 22:19:10
That’s looking very nice Phil. A lot going on in this build. You’d think building a pile of rubble would be easy, but I know how difficult it can be to make it look authentic. Doing a great job, keep it coming.Love Love Drool
Kev the Modeller
#75 Posted : 26 August 2021 16:16:40
Some very imaginative ideas going into this build Phil and nicely executed too. As Mark says, not easy to get it to look realistic and convincing, but something which you are skilfully achieving throughout the build.
Very well done indeed. Cool ThumpUp
Kev
Per Ardua Ad Astra
#76 Posted : 27 August 2021 10:08:56
Well thanks guys for the great commentsBigGrin i`m only following my instinct on how it would look after months of fighting Cool i have found some interesting photo`s of the plant so using them as reference Cool
Regards PhilCool
#77 Posted : 28 August 2021 09:59:58
As i have said looking at pictures of the plant i noticed the rail line behind the factory Blink so i decided to put some track in here BigGrin then just built it up and tried it along with the plant itself and the perimeter wallBigGrin
#78 Posted : 28 August 2021 16:54:10
Looking good, very impressed with your work Phil, adding a track will also improve the build and give you more room to place even more rubble, it will also make the eye look through the build to the rear instead of stopping short. Keep it going I wish you well.
Trev
Kev the Modeller
#79 Posted : 31 August 2021 13:17:27
Really coming alive now Phil and adding that railway line is a bonus that really improves the overall scene and makes it even more believable?
Brilliant stuff, looking forward to the next update already! Cool ThumpUp
Kev
Per Ardua Ad Astra
#80 Posted : 02 September 2021 21:16:47
Thanks guys for your comments i`m glad you like it so farCool
Regards PhilCool
6 Pages «<23456>
This page was generated in 0.410 seconds.
