3 Pages <123
Bfam's Porsche Options
bfam4t6
#41 Posted : 06 September 2021 22:36:13
Publisher Medal: Featured Build of the MonthBuild-Diary Medal: Build-Diary Medal of Honour
Next up is the dash.
For a bit of reference, the real car:
As usual, pretty much everything got sanded and most got painted. The stock dash actually had a really nice, satin-ish finish. However, it had a few too many exposed rough spots that needed filling.
I kept the stock chrome center pieces.
The top of the dash was all covered in leather. Did my best to cut out the openings for the defrost vents. There was a bit of a gap between the two top dash pieces, leather wrapped or not, but I'm anticipating it not showing up once installed and there is no light penetrating the gap.
The steering wheel was pretty bad. Not only was it slightly bent (which was pretty easily fixed with a flat table and some pressure) but the edge of it was about as rough as a ridged coin edge. It's hard to tell in my compressed photos, and I forgot to take progress photos. The final result cam out pretty nice though.
All the lower dash parts got the same treatment.
A bit of test fitting without the all the lower dash.
-Dustin
“Details make perfection, and perfection is not a detail.”
-Leonardo Da Vinci
Currently Building:
Porsche 2.7 RS
Currently Collecting
Jaguar E-Type, Ferrari F40, Ferrari 250 GTO, Lamborghini Miura, Ford GT40, Ecto-1, Japanese Zero, Porsche 917, Lancia Stratos
#42 Posted : 07 September 2021 07:59:52
Looking good. Cool Cool Cool
Also congrats for being "Build of the Month" for which you have been awarded your "Green" medal.ThumpUp
#43 Posted : 07 September 2021 09:08:57
Looking really great.
Nice to see another one getting the carpet and leather treatment.Love
bfam4t6
#44 Posted : 08 September 2021 01:12:29
Wow, not sure I deserve build of the month, but I do appreciate it. I should have some more updates soon
-Dustin
-Leonardo Da Vinci
Currently Building:
Porsche 2.7 RS
Kev the Modeller
#45 Posted : 09 September 2021 16:13:13
Very nice work Dustin, especially with the added leather and carpet fitting, really adds another level and brings the whole model to life?
Very well done! Cool ThumpUp
Kev
Per Ardua Ad Astra
#46 Posted : 11 September 2021 08:54:38
Very nice work Dustin. I finished my dashboard with leather too, makes all the difference.Love Love
bfam4t6
#47 Posted : 30 January 2022 16:17:09
Thanks guys!
My job has been crazy this past year, so I've had much less time for model building. I also got distracted a bit with some other kits, so not all of my efforts went into the Porsche.
Anyways, some progress has been made. Work has begun on the front end.
Some of the crevices were poorly coated, so I touched them up with some Tamiya white and an airbush. These are the before pics
Stock firewall. This was cleaned up and painted white.
As usual, I found a handful of reference photos online. Here are a couple. I knew I wanted to add some extra details to the blower motor and vent assembly, so I dug a little deeper into those bits.
The blower motor needed a decent amount of clean up. I also had to trim it's "pegs" a bit until it mounted flush with the rest of its assembly. It was then painted and hose clamps were added.
I had the vent cover fully installed before I realized it would almost never be that shiny white inside. So I removed it and added some nice dirt and gunk to tone it down.
Next up, the fuel tank. The shiny gloss had to go. So I coated it in flat clear and added some light weathering. I also added the vent hose.
Test fitting some bits
Next up the batteries, which got some decals and wiring added to the terminals.
More test fitting.
I have since spilled half a bottle of super glue on my table and front end, which dried into a nice nasty clump that I've been slowly and carefully trying to remove. So I'll post some pics of that in my next update.
-Dustin
-Leonardo Da Vinci
Currently Building:
Porsche 2.7 RS
bfam4t6
#48 Posted : 15 December 2022 19:05:14
First, the decals I'm using are from Roymattblack. I meant to mention that in my last post about them. They really add some great details.
Next, I totally forgot I got to see a real version of the car up close a few years back! I wish I had known I was going to be building this model (and also drank a few fewer whiskeys LOL ). I would have taken more than one photo! I had a pretty bad camera at the time too. Anyways, I wanted to share it.
This was the "Porsche Room" and had special admittance tickets, so all the cars were pretty special...unlike my photography skills.
Back to the build...
Here is my front end after falling victim to an unnoticed spilled super glue bottle. I used acetone to remove the super glue. I probably should have just soaked and stripped completely, but I'm still playing with this airbrush, and really wanted to test my blending skills on something that wasn't a prominent body panel. So, there was a bit of filling and sanding. For paint, I tried Vallejo white at first, but Tamiya seemed a better match in the end.
Painted the hood release/catch. Overall I think it turned out pretty well.
I don't think the rest of the front end deserves another full post, so to try to quickly sum up the rest, before I just do a photo dump...
-Anything rough was sanded, and painted if necessary.
-Everything was weathered
-Added wires
-Added mini zipties
-Added hose clamps and hex hardware
-Added "vacuum lines"
-Added washer fluid hose
-The blower motor cover was fun to customize. I was tempted to go even further, and completely customize all the mounts, but after breaking one peg (the upper left if viewing car from front), I decided to not overcomplicate things, and just keep the original mounts. This also allowed me to install the cover without screws, so it can be removed to see the details underneath, if desired.
-Pardon the layer of dust on everything.
At some point, I may come back and cut the battery straps, and replace them with a threaded rod and some typical metal battery clamps.
Photos:
-Dustin
-Leonardo Da Vinci
Currently Building:
Porsche 2.7 RS
#49 Posted : 16 December 2022 09:42:49
That is looking really great. Some lovely added details.
I'm glad you're enjoying the build - it's a great kit.Love
#50 Posted : 16 December 2022 18:43:30
That is some stunning building there, the photos towards the end of the boot section had me wondering if they were the model or reference photos of the real thing - and that's the sign of a masterpiece!Cool Cool Cool
And congratulations on the sorting out of the super glue spill! No sign of it at all on the final photos. Are you like me, end up getting so fed up with constantly drilling out blocked nozzles that you take away the nozzle completely and rely on sticking cocktail sticks down in there to get at the glue? BigGrin
Works fine until you knock the darned bottle over!Blink
Brilliant work and well done!Drool
3 Pages <123
This page was generated in 0.230 seconds.
