10 Pages <12345>»
Tigerace`s 1/16 Trumpeter King Tiger Options
#41 Posted : 19 September 2021 13:08:36
Another creation of yours I'm going to enjoy following, especially with all the aftermarket parts you're adding.... will be watching.....Drool Drool Drool
Kev the Modeller
#42 Posted : 20 September 2021 20:42:56
Great to see you making a start on this impressive kit Phil. I will definitely be following and commenting throughout the build!
A nice steady start and boy do you have a long way to go 'til the finish, but I've no doubt that the end result will be worth all of that considerable effort over the next few months! Drool ThumpUp
Kev
Per Ardua Ad Astra
#43 Posted : 24 September 2021 12:10:51
Thanks guys and welcome to the journey of the Big Cat BigGrin
Regards PhilCool
#44 Posted : 24 September 2021 12:15:17
So the inside side sponson`s detail`s moulded on and the spare periscopes are the wrong way round ,i`ve marked them in red before i remove them the cables will be replaced with solder and some plastic rod the periscopes and holder are in with the after market ones i got from shapeways also i will replace the cable junction box, also on the rear the lug for the rear idler needs removing BigGrin
#45 Posted : 24 September 2021 17:31:03
A lot of work required there, but it will be worth it in the long run for the accuracy.
Keep up the good work.Cool Cool Cool
#46 Posted : 13 October 2021 11:25:21
Thanks Derek BigGrin yes needs a bit of correctionBlink
Regards PhilCool
#47 Posted : 13 October 2021 11:26:12
so removal of the moulded on periscopes and conduitBigGrin
#48 Posted : 13 October 2021 11:30:29
Then filled overBigGrin
#49 Posted : 13 October 2021 11:34:30
New parts added the shapeways spare periscope holders and the electric conduit made from 1mm solder ,plastic rod and the small bracket from some etch brassBigGrin
#50 Posted : 13 October 2021 11:37:52
The electric junction box next this is my first attemptBigGrin too bigCrying so started on making another BigGrin
#51 Posted : 13 October 2021 11:39:06
All the pin marks filled and then mr surfacer appliedBigGrin
#52 Posted : 13 October 2021 11:45:34
Where the interlocking plates meet on the lower hull they are not present so started on replicating them buy first marking them, then cutting them with a pcutter BigGrin then i will remove the piece with a micro chiselBigGrin add the plate marks BigGrin then add weld beads around the edgesBigGrin
#53 Posted : 13 October 2021 11:48:04
New arrivals Drool Drool Drool First 3d printed Extinguisher and Bosch HeadlightDrool Drool
#54 Posted : 13 October 2021 11:50:42
Then a New Engine Hatch which has the internal detailsBigGrin missing from the kit part this is from ShapewaysBigGrin
#55 Posted : 13 October 2021 11:52:56
Then a New Radio operators seat again from shapeways BigGrin
#56 Posted : 15 October 2021 12:17:27
Hi very nice start going to be a long build cheers mick.BigGrin
Kev the Modeller
#57 Posted : 16 October 2021 11:39:57
This is going to be one amazingly detailed King Tiger with all of these extras that you're adding Phil! Your build certainly has my attention and I will be following every step of the way - have fun! Drool ThumpUp
Kev
Per Ardua Ad Astra
#58 Posted : 17 October 2021 09:26:34
Very nicely done Phil. Some very nice detail going on.Love Love
#59 Posted : 19 October 2021 11:49:00
Well thanks guys for looking inBigGrin and your comments always appreciate them BigGrin
Regards Phil
#60 Posted : 19 October 2021 11:52:13
So the interlocking joints are now complete the rough texture is modelling putty layered on then using a scalpel to make the linesBigGrin then the weld beads applied these are from the archer range of decalsBigGrin
10 Pages <12345>»
This page was generated in 1.270 seconds.
