Robi Battery Connector Type? Options
AdamE
#1 Posted : 20 September 2021 00:23:51
Rank: Advanced Member
I am in the process of creating an extended battery for my Robi(s). I need to get hold of some battery male and female connectors but for the life of me I can;t figure what it's called.
It doesn't seem to be a JST connector, or Tamiya or anything that I can find available?
Thanks in advance!
#2 Posted : 20 September 2021 14:57:15
Yes its not a standard JST for sure.
AdamE
#3 Posted : 20 September 2021 16:07:35
After some image matching I found out it is a 2-pin JST-PA type plug.... Seems to not be used much LOL
So now I just need to get some plugs/ sockets, make up a back panel with the socket in it, extend the battery wires and I'll have a 1000mAh or 1400mAh (if I don't mind a bigger 'backpack') in him - finally more run time!
#4 Posted : 20 September 2021 18:15:18
Hi Adam, BigGrin
Personally I have had lots of results, (as have others I know), from the company in the link below. You can also speak to them direct for assistance:
https://www.bclstore.co.uk/shop
Phone numbers at the bottom of the contact page.
AdamE
#5 Posted : 21 September 2021 00:13:29
Cool will check them out!
Hi Adam, BigGrin
This page was generated in 0.228 seconds.
