52 Pages «<3940414243>»
1/48 scale U-Boat U230 [Part 3] Options
Sticky Wickett
#801 Posted : 14 October 2021 20:54:58
From another angle.
Sticky Wickett
#802 Posted : 14 October 2021 21:01:04
I then fitted out the worktops for the Wireless Transmission [W/T] shack. The height is made up of short lengths of 4mm square section acetal, giving a height of approximately 2 feet in real life when stacked giving a model height of 12mm. This is about right, as i measured the height of my knee when sat down, so know the proportions are about there. The tops were painted green and the edges lined with mahogany veneer. The deck at this stage looks a little scuffed while i fitted out the access doors, but i'm going to leave it as is, thinking that the watchkeepers stools would of worn it like that.
Sticky Wickett
#803 Posted : 14 October 2021 21:06:46
The W/T shack is fitted with all manner of amplifiers, transmitters and receivers. The first item i made is a morse code translator, i believe. Acetal sheet of varied thickness was glued together to give the profile and the knobs were made of 1.6mm and 1.0mm diameter acetal rod, cut to length, painted matt black, glued in place and their tops painted either red or yellow. The bearing indicator was made from 0.25mm thick acetal sheet using a compass cutter and the edges and dial indicator drawn on free hand.
Sticky Wickett
#804 Posted : 14 October 2021 21:08:20
Device fitted with the morse code tapper and connecting wire.
Sticky Wickett
#805 Posted : 14 October 2021 21:09:32
A tiny speaker made up using acetal sheet and a bit if wire mesh. This speaker was so that watchkeeper can hear orders sent around the U-boat.
Sticky Wickett
#806 Posted : 14 October 2021 21:09:54
Speaker fitted.
Sticky Wickett
#807 Posted : 14 October 2021 21:12:35
The next item i made was an amplifier. Pictured against a 5p coin to give an idea of scale.
Sticky Wickett
#808 Posted : 14 October 2021 21:13:05
Amplifier fitted.
Sticky Wickett
#809 Posted : 14 October 2021 21:14:50
I then made a reciever [?] from a 4mm square section acetal, cut to length, front face filed at an angle and a couple of black knobs added, made from 1.0mm diameter rod.
Sticky Wickett
#810 Posted : 14 October 2021 21:17:18
I then made 3 sets of headphones. Using 2.0mm diameter acetal rod, i cut 6 discs, painted them black and joined them together via a small length of 0.7mm diameter solder. I test fitted each set on to the head of a watchkeeper, so i know the proportions are about right.
Sticky Wickett
#811 Posted : 14 October 2021 21:18:48
One set of the headphones, plugged into the receiver and hanging off the two knobs.
Sticky Wickett
#812 Posted : 14 October 2021 21:20:26
From another angle.
Sticky Wickett
#813 Posted : 14 October 2021 21:21:11
Receiver and headphone set fitted.
Sticky Wickett
#814 Posted : 14 October 2021 21:22:20
That concludes this weeks update. More to follow next week.
Thanks for looking in, have a great weekend and happy modelling!BigGrin
Phil W.
goddo
#815 Posted : 15 October 2021 09:54:34
Great attention to the little details.
Brilliant.
Chris
Kev the Modeller
#816 Posted : 16 October 2021 11:34:58
More amazing work from you Phil (though I never expect anything less from you), always brilliant! Some of those scratchbuilt pieces are tiny, so well done you for persevering with all of those little details, they really do make a difference to the finished build!
Keep it up Phil, always looking forward with bated breath to your next update. Cool ThumpUp
Kev
Per Ardua Ad Astra
#817 Posted : 16 October 2021 21:03:16
I love all the scratch built instruments Phil - lovely work and it takes me back to many happy hours playing Silent Hunter 3 on the pc, I remember all those instruments from the various watch stations which I always seemed to end up in after pushing the wrong key whilst being depth charged (well, anyone can panic!Blushing ) Great work as always!
Robin.
#818 Posted : 17 October 2021 09:32:00
I’m almost ran out of things to say. Just brilliant work. This should be in a museum when finish for all to see and enjoy.
Sticky Wickett
#819 Posted : 21 October 2021 18:48:10
More progress this week on fitting out the W/T and Sonar shacks.
The attached photo shows the W/T watchkeeper, painted and pin washed.
Sticky Wickett
#820 Posted : 21 October 2021 18:49:25
The watchkeepers seats were then covered in leatherette. Only one shown here.
This page was generated in 3.326 seconds.
